PROBLEM w/ NEW master key...
Old 12-11-03, 08:45 PM
varcity64
varcity64's Avatar
Unhappy PROBLEM w/ NEW master key...
i tried doing a search, but really didnt come up w/much. i have a 2000 GS300. i only had 1 master key and 1 valet key. soooo, i ordered a new cut master key. i was able to program the key to start the car, but the buttons (unlock, trunk, and panic) DONT WORK the ONLY reason i spent so much money on another key was so i could have 2 master keys w/working buttons. PLEASE HELP...
Old 12-11-03, 09:09 PM
squarehat
squarehat's Avatar
Try these instructions (for an RX, should have the same 3-button key). I'm pretty sure these are for the keyless entry transmitter (not the immobilizer transponder), because they don't involve the brake pedal pushing like the transponder.
https://www.clublexus.com/forums/sho...rogramming+key
Edit, try this thread for (explains a 99 LS in a little bit simpler detail). Instructions are from VVT-i, a moderator here and Lexus technician, so they should be accurate. https://www.clublexus.com/forums/sho...ey+transmitter
Old 12-12-03, 01:00 AM
SeattleGS400
SeattleGS400's Avatar
This PDF is for a '98 GS400--it uses the same key, so give it a shot!
File Type: pdf
Old 12-12-03, 01:06 AM
SeattleGS400
Here's more info in this PDF for reprogramming
File Type: pdf
natedahms
05-15-18 02:47 PM
brianjb
RX - 1st Gen (1999-2003)
01-30-16 05:35 PM
rashanp102
10-09-12 11:41 AM
ruski
09-30-04 08:24 PM
RelaxJoe
06-17-04 08:29 AM
Quick Reply: PROBLEM w/ NEW master key...
