Question regarding transmission fit
Old 05-21-15, 12:42 PM
shurik74
shurik74's Avatar
Default Question regarding transmission fit
Dear CL members...
I found one '13 GS350 AWD that having problems with tranny, my buddy has one sitting in the shop came off 13' GS350 RWD base model. Question would be if they are the same, so I can swap it w/out any problems...
Thank you in advance
Old 05-21-15, 03:42 PM
gotink
gotink's Avatar
Should be the same. 6 speed
Old 05-21-15, 04:38 PM
shurik74
shurik74's Avatar
Thank you...
Anyone else might know? I have to make a decision by tomorrow morning...
Old 05-21-15, 05:43 PM
bclexus
bclexus's Avatar
Received 2,276 Likes on 1,622 Posts
Originally Posted by shurik74
Dear CL members...
The GS350AWD transmission is a A760H
The GS350RWD transmission is a A760E
Old 05-21-15, 06:19 PM
shurik74
shurik74's Avatar
Sounds like there is difference even though they both have 6 speeds. I just wonder if still gonna work with buying couple extra sensors etc or it's completely different model
Old 05-21-15, 06:44 PM
bclexus
bclexus's Avatar
I wouldn't consider it anymore than I'd consider trying to put a John Deere corn picker transmission in it.
My question is - a 2013 GS 350 should still be under factory warranty. Why does this particular GS 350 have a bad transmission that Lexus is not fixing/replacing? This doesn't make any sense...
Old 05-22-15, 04:37 AM
balfor
balfor's Avatar
can't swap a RWD trans into an AWD as it won't have the transfer case built in. Maybe you can take the trans apart and add the transfer case onto the RWD trans, but I wouldn't risk it as there might be other differences.
Old 05-22-15, 05:39 AM
rjm
rjm's Avatar
What was the problem with the '13 GS350 AWD transmission?
Old 05-22-15, 07:24 AM
shurik74
shurik74's Avatar
Thanks a bunch for your input
Car is on auction, description says "rear gear is not working...". I had to assume the worse case scenario if I need to replace tranny
Yes, you are correct... but there is certain conditions when dealer will do fix under warranty, if there is like undercarriage damage, they won't. Problem is that I can't check out GS in person. Tried to do some homework...
Again... thank you guys for all your input! CL is a great community
Old 05-22-15, 12:18 PM
bclexus
bclexus's Avatar
shurik74, if the car is an auction car - there is a good reason for it. My suggestion is to forget about that car entirely...and don't look back. Let the ripoff artists offering high-end used cars at independent used car dealerships (that you wonder how and why they acquired them instead of dealerships) buy that car at auction, repair it [to some extent], and then resale it to some unsuspected buyer that will one day learn that Lexus will not warranty the vehicle.
Gs3500
09-21-15 06:54 AM
PerpLexusd
12-15-13 07:50 AM
boney31
SC- 1st Gen (1992-2000)
08-06-10 08:04 PM
bocha
ES - 5th Gen (2007-2012)
06-30-08 12:22 AM
Quick Reply: Question regarding transmission fit
