Jumping, while cornering
Old 05-10-15, 06:28 PM
jmoney6
jmoney6's Avatar
Default Jumping, while cornering
The other day, I saw a very cute girl driving an audi and of course wanted to impress her with some aggressive driving.
we were both at a stop light turning left, she on the inside me on the outside. I put the car in s+ and went halfway through the turn the car started jumping from the front end. It could have been a bump int he road but it made me nervous. Any oen else have a similar issue? It also seems like with the 19's I get some running once in a while.
Old 05-10-15, 07:20 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
No. But when I floor mine when turning I drift! I always do that in my work parking lot when nobody's there and did that once in the rain, it was scary and fun at the same time.
Old 05-10-15, 07:45 PM
bclexus
bclexus's Avatar
Received 1,991 Likes on 1,415 Posts
we were both at a stop light turning left, she on the inside me on the outside. I put the car in s+ and went halfway through the turn the car started jumping from the front end. It could have been a bump in the road but it made me nervous. Any oen else have a similar issue? It also seems like with the 19's I get some running once in a while.
So, let me see if I got this right. The cute girl in the Audi made you nervous and she beat you turning left at a stoplight. Now you're trying to blame her beating you on a bump in the road. Did she stop to find out what happened to you, or did the cute girl drive away in victory? Do you have any idea if you impressed her?
Old 05-10-15, 09:06 PM
ItzFilyO
ItzFilyO's Avatar
U don't need to impress any girl if u have Kate. No jumping needed.
Old 05-10-15, 10:23 PM
sam430
sam430's Avatar
When i try impressing a girl, i go straight for the light pole, but that's me though.
Old 05-11-15, 06:16 AM
jj14
jj14's Avatar
I've noticed the front end of the GS jump when taking a corner aggressively too. Almost like the car isn't turning fast enough to keep up with the rear wheels pushing it.
First thought was that maybe my front tires need to be replaced, but they have really good tread on them - and the tread is even. This is on dry paved road, so I didn't expect this to happen.
Old 05-11-15, 06:42 AM
Justin2JZ
Justin2JZ's Avatar
Lmao at the OP
Old 05-11-15, 07:21 AM
bclexus
bclexus's Avatar
Yep, you have Kate Upton - now that is impressive!
Old 05-11-15, 07:59 AM
GSTONY
GSTONY's Avatar
I don't find that issue since my gs was a dedicated track car for a year and a half never did I feel any jump.
Old 05-11-15, 08:12 AM
ItzFilyO
ItzFilyO's Avatar
FWD cars have that wheel hop issue sometimes but the GS is RWD and shouldn't have that issue.
Old 05-11-15, 08:42 AM
bclexus
bclexus's Avatar
The OP should read about Ackermann Steering Geometry and also about Scrub Radius and Squirm.
When a RWD car with a tight suspension and wide tires makes a small radius turn at a slow speed, one of the front tires can slip, jump or jerk.
Old 05-12-15, 12:18 PM
OHITSKINO
OHITSKINO's Avatar
Sounds like you experienced a bout of the dreaded understeer. Gross.
Old 05-12-15, 06:39 PM
Afrosheen
Afrosheen's Avatar
If it was under steering, you were in the wrong gear, turning too sharply, or not feeding it enough gas. RWD cars tend to oversteer if anything.
Still, chasing a girl in an audi? You can do better bro.
Old 05-12-15, 07:44 PM
AL13NV8D3R
AL13NV8D3R's Avatar
My car too has this dreaded hop at mild speeds during turns. Only when i sport+ mode and only while making a left turn with moderate pedal travel.
This problem does not occur when I take my car to the race track for a track day. When on the gas heavy or full throttle while turning left it does not exibit this problem at all. I have no problem drifting this car on the track.
But because this car has low torque its quite hard to maintain a long consistent drift. All my other RWD cars in the pass does not have this problem, that the GS has on sharp left turns with moderate throttle.
Old 05-13-15, 04:48 AM
OHITSKINO
OHITSKINO's Avatar
All cars will understeer depending on how they're driven. It's just possible to get RWD cars to oversteer... very hard for an FWD or even AWD to oversteer. I'm willing to bet that the OP went through the turn too slowly but was attempting to turn too sharply. Hence, understeer. A little bit of throttle would solve that problem nicely.
Quick Reply: Jumping, while cornering
