60k service
Old 04-13-15, 11:15 AM
pacmanmmc
pacmanmmc's Avatar
Default 60k service
How much does your dealer charge for the 60k mile service ?
Dealer is asking $590. I have a 3rd generation GS and don't remember any service being that much.
Old 04-13-15, 11:40 AM
richard203
richard203's Avatar
Wow u drive a lot drove 60k already?
Old 04-13-15, 11:44 AM
Rudiculous
Rudiculous's Avatar
It's a 3GS…
I would honestly recommending calling local dealerships to find the best price. Then ask your preferred dealership to price match
Old 04-13-15, 11:53 AM
pacmanmmc
pacmanmmc's Avatar
20K a year on on 13 GS.
I'm 500 shy of 60k
Old 04-13-15, 11:57 AM
pacmanmmc
pacmanmmc's Avatar
Originally Posted by Rudiculous
It's a 3GS…
Thanks ! Will do
Old 04-13-15, 11:59 AM
dchar
dchar's Avatar
I remember dealer asking for about that much for 30K service. I'm assuming they are replacing pads. I ended up telling them to do the service but not to replace pads, buying the pads online, and taking it to my local shop to replace.
Old 04-13-15, 12:20 PM
pacmanmmc
pacmanmmc's Avatar
Not replacing pads. Replacing air filter , fuel filter, cabin filter , rotate tires, oil change.
Old 04-13-15, 06:20 PM
faifai83
faifai83's Avatar
Is the fuel filter replacement on the manufacturer's maintenance schedule?
Old 04-13-15, 06:29 PM
Ford1776
Ford1776's Avatar
I don't think there is a serviceable fuel filter. These days it is in the fuel tank as part of the fuel pump
Old 04-13-15, 06:33 PM
faifai83
faifai83's Avatar
Can you provide a breakdown of the $590?
Oil Change - $100
Tire Rotation - $20
Engine Air Filter - $30
Cabin Air Filter - $50
Rotating windows, Topping off air in air bags, changing blinker fluid - $390?!?
emak (03-02-21)
Old 04-13-15, 06:42 PM
onexcite
onexcite's Avatar
$390 for the labor & car wash! LOL
IMO unless 60K included flushing tranny fluid and transfer case fluid otherwise dealer charge are ripped off.
Oil change could be done at any shop for $75 synthetic if you lazy to do. Both filters could be replaced under 5 minutes. Your tires properly replaced by now and tire shop will do rotation for free. The money saving could be use toward a nice bubble spa and details for your ride.
emak (03-02-21)
Old 04-14-15, 09:11 AM
islandbeef
islandbeef's Avatar
60k miles and you're still going to the dealership?
You must really like the free cookies and sodas, huh?
emak (03-02-21)
Old 04-14-15, 04:17 PM
pacmanmmc
pacmanmmc's Avatar
The actual price of the 60k service is $1000.
I'm bummed but after further research on the forums , I think I'll pony up and get the service. I know I'm getting ripped off but I'm a fanatic regarding my car & I won't trust anyone else to service it for me . I also want to keep it in tip top condition.
Old 04-14-15, 04:29 PM
bclexus
bclexus's Avatar
Received 1,996 Likes on 1,418 Posts
60,000 Mile Service:
Replace engine oil and oil filter (0W-20)
Rotate tires (Applies to models with the same size front and rear tires and wheels.)
Replace air conditioner filter
Replace brake fluid
Replace engine air filter
Replace smart key battery
Replace spark plugs
Measure brake pad thickness and rotor runout
Reset maintenance reminder light
Road test vehicle
Check installation of driver's floor mat
Inspect axle shaft boots
Inspect ball joints and dust covers
Inspect body
Inspect brake lines and hoses
Inspect drive belt(s)
Inspect engine coolant
Inspect exhaust pipes and mounting
Inspect fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses.
Inspect fuel tank cap gasket
Inspect rack and pinion steering assembly
Inspect rear differential oil
Inspect steering linkage and boots
Inspect transmission for signs of leakage
Visually inspect brake pads, calipers and rotors
Old 04-14-15, 04:55 PM
pacmanmmc
pacmanmmc's Avatar
Thanks !
My service guy sent me a breakdown of all the work with the total price.
Quick Reply: 60k service
