IS rims/wheel to 4GSF
Browsing the wheels in the Classified forums, I notice a lot of 20" wheels from IS being sold. Is there a major difference in fitment and/or offset if trying to put on 4GSF? Wondering if they can easily plug n play?
I bought a set of 20's from a forum member that was running them on an IS350. Offset and size was right on for the GS.
The issue is the tires, the IS has to run 30 series front tires for clearance on 20's, and the GS needs 35 series to keep the same rolling diameter. You will most likely need to replace the front tires if you buy a set off an IS. Keep an eye on front tire size, otherwise you are good to go.
