F-Sport Headlight not bright enough
Old 01-29-15, 06:15 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,050 Likes on 664 Posts
I'm just happy the 4GS finally get LED DRL instead of half powered halogens.
Old 01-30-15, 01:17 PM
tknx
tknx's Avatar
A couple of thoughts.
1. When adjusting your headlights, make sure the low beams are pointed below your sideview mirrors (point them at a wall to compare). Otherwise you will be blinding other people.
2. Acura cutoffs are because of the clear lens - you can lens mod it like TRSMatt did.
3. You may also want to try a top end bulb like a CBI or Philips. They aren't cheap.
Old 10-19-15, 11:50 PM
NVMYLEXX
NVMYLEXX's Avatar
Default Is 250/350
I have a question. Why does the IS 250/350 DRL's brighter then the GS350 F sport ?
Old 10-20-15, 12:32 AM
dchar
dchar's Avatar
If you're referring to the current gen IS, then it might seem brighter because the IS has quite a few more LEDs for the DRLs than the GS.
Old 02-10-16, 04:38 PM
NVMYLEXX
NVMYLEXX's Avatar
Default Hey
Originally Posted by johnphan79
Hi All,
After driving my 2013 GS350 F-Sport for sometime at night. I notice the headlight is not as bright and F-Sport doesn't come with Foglamp.
I have couples questions..... hope u can help.
1. Does anyone know what kinda light buld does BMW n Mecerdes use? I noticed the color is much brighter and white/purples. (Sorry, i like bright light. My wife 2nd Gen GS had 6K HID for both Low/High beam.)
2. I live in 818 - Woodland Hills Area. -Does anyone know where i can get the foglamp install professionally? OEM parts and all. Sorry, no halfass work ;-)
-If you have the pricing thats would help alot too.
Thank you all
Same here... I thought I was the only one that noticed that with the color temp and the way the Bmw and Benz look. White/Purple/Blue ish
Old 02-10-16, 04:40 PM
NVMYLEXX
NVMYLEXX's Avatar
Default Question...
Originally Posted by praetor
Don't confuse color for lumens. Our eyes will perceive bluish purples as being brighter when in actuality it is less lumens. But if you want that bluish purple headlight look go up to a 8K HID bulb. Philips/Osram is a good brand. Don't go for the cheap eBay stuff.
So all I need to get is a D4S 8K Bulb and swap it with the factory 4300k?
Old 02-10-16, 05:30 PM
Sevn86
Sevn86's Avatar
Yup, get the correct bulbs and swap them out. I personally wouldn't go that high. I feel 6k would give you the look your looking for.
Old 03-07-16, 05:43 AM
Bj(CA)
Bj(CA)'s Avatar
is it hard to switch out the hid bulbs? I like the 6000k look
Old 03-07-16, 09:05 AM
jtrue28
jtrue28's Avatar
The driver side swap is a PITA. If you have large hands, good luck. There is an access panel inside the wheel well on the driver side. Turn the wheels all the way to right to give you space to take that panel off.
I think someone posted a step by step somewhere in here...
Old 03-09-16, 03:45 AM
Bj(CA)
Bj(CA)'s Avatar
thanks, but couldn't find the DIY, not even on you tube.
cant decide between the phillps and osrams
Old 03-09-16, 05:14 AM
jtrue28
jtrue28's Avatar
Easy. Philips and it's not close. Get the Ultinon bulbs (D4S).
http://www.nigel-jdmparts.com/philips-ultinon-6200k-d4s
As far as removal and installation goes:
- Twist the ballast off (big silver box connected to the light assembly)
- Undo the cable from the ballast to the bulb
- Squeeze the clip that is holding the bulb in. It is hinged on one side, so once it is free of the assembly just fold it back
It will look something like this.
- Pull the bulb out. Can't remember if you have to also twist it or not, but just pay attention to how it is situated in the assembly so that the new bulb goes in the same way.
- Do all of the other steps in reverse order.
It's not hard. Once you get in there and start doing the change, all of these steps will make sense. I would do the passenger side first so that you get all of the steps down and know what to do.
Most of the time they tell you to disconnect the battery, but I didn't.
VERY IMPORTANT: DO NOT TOUCH THE GLASS of the bulbs.
Old 03-09-16, 06:01 AM
Bj(CA)
Bj(CA)'s Avatar
thanks for the tips man, nigel jdm has a nice price, I hope its genuine.
Old 03-09-16, 08:55 AM
nerv81
nerv81's Avatar
I know some people say fog lights don't help much but I have to disagree. I live in a wooded area with very little street lighting. I didn't get the f-sport because I wanted fog lights (i found out later that they could be added). But the oem halogen fog lights didn't help much so I installed the LED fog lights from theretrofitsource.com (https://www.theretrofitsource.com/co...hts-lexus.html). They're similar to the OEM Lexus LED fog lights just cheaper. You should see if you can install these with the fog light kit for the F-Sport. They make a huge difference and I have them on my GS and RX. My wife instantly noticed a difference.
Old 03-09-16, 06:38 PM
Nigel-JDMParts
Nigel-JDMParts's Avatar
We only sell genuine.
mrpartsman
10-04-22 02:30 PM
SNiiP3R
01-07-21 06:46 AM
trailhiker
NX - 1st Gen (2015-2021)
25
10-30-17 06:30 AM
iJDMTOY
Club Lexus Vendor Marketplace
31
01-06-17 05:37 PM
bigblack06
01-25-13 02:45 PM
Quick Reply: F-Sport Headlight not bright enough
