Fan blower noise when on high and circulating air
Hi - My GS350 barely has 20k miles and started doing this recently. When I would have the fan in "circulate air" mode and blower on highest, the blower makes a very loud buzzing noise and strong vibration. The blower is on the passenger side next to the glove box. When the air is pass through it does not do this.
Has this happened to anyone and what was the cause? I will need to get it to the dealer soon
Yes, dealer time.
You could take a peak at the air filter compartment to see if you have any debris in the area. It's in a compartment just behind a panel inside the glove box... just make sure you have the system set to allow fresh air in before attempting to open the air filter compartment or you may break some parts.
Taking it in this Friday and will report back. I checked the cabin air filter and nothing, no debris. I've read most likely something is stuck in it, hopefully not a rat eeeek! It seems other models on clublexus have had similar issues.
I have the same issue, I turned the blower and A/C off and the noise is still there so I recorded it, so I can show it to the dealer next week, my luck when I get there there will be no more noise, and they will say there is nothing wrong.
Today is the day huh... any updates here?!
Hey guys- Just reporting back from my trip to the dealer yesterday. So as it turns out, there was debris found in the blower underneath the cabin filter. A while back, I replaced the cabin air filter on my own and thought that was that. According to the dealer, the air cabin filter was installed wrong and it dropped debris beneath. Anyhow, I paid the dealer to remove the debris and noise is gone. So let it be a caution to all, be careful when replace the cabin air filter. It's not as simple as it seems...go figure. Honestly, I am still scratching my head as to how I went wrong with this simple procedure...but its all water under the bridge now...
Definitely will note to install that filter properly in the future, I guess it was in backwards... I think there should be an arrow that shows the directional flow on there, havent done mine yet though.
GStatus
01-07-16 10:44 AM
