So I put the stock suspension back, but now the rear looks funny
#106
^^^^ not sure what to say. I was hoping for the dealer to find the problem, but they all said the same thing that everything is fine. I'm just out of options here at this point. Someone in this thread said that it took 2 months for his car to drop to normal height, maybe mine will too eventually.
#107
#108
I'd like someone to explain what 'settles'. Springs don't somehow magically shorten or compress after being installed on the shock/strut for a period of few days, weeks or months. Let's hope they don't! The springs are made of high tensile spring steel and are designed specifically for a particular preload mass, force range and travel distance. The springs will not settle. There may be a bit of change (drop) if a spring is not installed correctly in the perch and rotates to seek the proper position after a period of driving, but the springs themselves will not settle (sag, shorten or compress).
#109
#110
I'm not sure what Lexus does at the factory. Most likely they compress springs before they are installed.
The springs are seated properly. Mines are not sagging, it looks like they've expended by an inch. It makes sense if they were laying around for almost a year with no weight.
#112
Going down an entirely different path, a change in tire size, with sidewall dimensions being the most important, could have a small impact on fender gap. Also, tread depth wear (new versus worn) can amount to as much as 5/16" difference.
There is one thing I know - don't count on those Toyota/Lexus OEM springs to change their designed rate and soften, sag, or settle. If the wheel gap reduces any, it won't be the spring ratings that magically change.
#113
I'm curious - did the installer re-tighten any suspension pivot points (control arms, strut mounts, roll/sway bar, etc.) with the car up off the ground on a lift but with the suspension still dropped or unloaded? That's a no-no...and this is the very reason why some people's car takes a while to [so-called] 'settle' after changing springs - it is not the springs settling, but instead the tight pivot point bolts that were tightened without the car's weight loaded on the suspension.
#114
#115
Congrats on the newborn! I, too, had a newborn when I bought my GS. I couldn't keep it stock with that wheel gap though. CL actually made my decision easier since most said Tanabes feel like stock. Plus if it was too rough for my baby, I would have just gone back to stock. I actually think my baby sleeps better with a slightly rougher ride. If I were you, I'd put back the coil-overs and dial it to your softest setting. I had to lol hard when I saw the pic of your car on page 1. That wheel gap is as big as the Mercedes SUV behind you. Too bad you sold your rear Lexon diffuser. And too bad I missed out on it. Lol. Good luck in figuring out your suspension problem. There's definitely something wrong.
#118
They were scratching their heads just like the guys who did the install.
That might do the trick. I need to find a lady like that to sit on the hood for 2 - 4 hours.
