Fog-lights Installed Again!
Old 01-13-15, 03:44 AM
bigblack06
bigblack06's Avatar
Default Fog-lights Installed Again!
Finally got my fog-lights installed again love the look and the ability to drive around with only fogs on. Please ignore my ashy tires as it was cold and salty!
Old 01-13-15, 04:40 AM
BlueAc215
BlueAc215's Avatar
Looks good. Did you install the OEM stalk as well or just a separate switch?
Old 01-13-15, 06:48 AM
bigblack06
bigblack06's Avatar
OEM stalk.
Old 01-13-15, 10:03 AM
ARISTOh
ARISTOh's Avatar
how do you get your fogs to turn on with the DRLs?
Old 01-13-15, 10:08 AM
FuzedOne
FuzedOne's Avatar
About how much did this whole fog light project run about? I want to do it, but it adds up very fast,
Old 01-13-15, 11:01 AM
islandbeef
islandbeef's Avatar
I've been wondering, does this fog light upgrade affect the car's computers OR is it just a "plug and play", like adding an HID ballast to your headlights?
Old 01-13-15, 11:14 AM
bigblack06
bigblack06's Avatar
They wired it up that way so it would work with just the switch turned on. The OEM foglight switch can turn the lights on and off alone as well.
Well it was cheaper this time around. Came out to be $485 if you include the stalk and the fog lights thats different cause I had it from my other car.
Seems to be plug n play with wiring it. Aside from the having to add wiring it is pretty much plug n play with OEM stalk.
Old 01-13-15, 12:09 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Congrats on Round 2...
Can't believe they have been selling the FSport "Foglight" less since January 2012 ..!!!
~ Joe Z
Old 01-13-15, 12:14 PM
yardie876
yardie876's Avatar
Ugh I have to figure out why mine aren't working. I had the installer look at it and he said I need to replace the clip on the harness because it's loose and he'd order another one for me but he's gone ghost so I'm stuck now. Don't think my local dealership will even touch it...
Old 01-13-15, 02:49 PM
islandbeef
islandbeef's Avatar
^that's probably why my independent mech is afraid to tackle this upgrade.
Old 01-13-15, 06:35 PM
bigblack06
bigblack06's Avatar
Yes this happened on my first foglights install was fixed by replacing but that was it.
Old 01-13-15, 06:37 PM
bigblack06
bigblack06's Avatar
Originally Posted by Joe Z
Congrats on Round 2... Can't believe they have been selling the FSport "Foglight" less since January 2012 ..!!! ~ Joe Z
Thanks. I can't believe that either since so many want it.
Old 01-13-15, 07:01 PM
yardie876
yardie876's Avatar
Do you exactly know which part of the harness that was replaced? I want to just replace it myself but I don't know which piece it even is smh.
Old 01-14-15, 04:29 AM
bigblack06
bigblack06's Avatar
If its the same as mine I think all you need to replace is the H11 harness part which I believe he cut and rewired.
Old 01-14-15, 06:58 AM
neegroy
neegroy's Avatar
whered you get the license plate mounts OP
i love the fogs. one reason why i went with the luxury gs, until later i found out the f sport had an option to add the fogs -.-
Quick Reply: Fog-lights Installed Again!
