Need Help -- Recommendations for 20" rim tires?
Old 01-12-15, 06:26 PM
Jumusiq
Jumusiq's Avatar
Default Need Help -- Recommendations for 20" rim tires?
Need Help -- Tire size and model recommendations for 20" concave rims on 2015 GS 350?
Front: 20X9
Rear: 20X10.5
Old 01-12-15, 07:30 PM
LexRuger
LexRuger's Avatar
245/35/20 front 275/30/20 rear Pirelli is my favorite tire brand.
Old 01-12-15, 07:38 PM
Jumusiq
Jumusiq's Avatar
[QUOTE=LexRuger;8865239]245/35/20 front 275/30/20 rear Pirelli is my favorite tire brand.[/QUOTE
There should be no rub on the front of I go 35 right? Do you know if I leave the car stock without dropping how big the gap will be? Will it be bigger than stock tires gap?
Old 01-12-15, 08:09 PM
LexRuger
LexRuger's Avatar
rubbing depends on the offset. unless you use a very aggressive offset, it shouldn't rub.
the 20" tire will be the same height as the stock tire so the gap will be the same.
Old 01-12-15, 09:44 PM
PirelliRC
PirelliRC's Avatar
for the Pirellis
Old 01-13-15, 04:11 AM
Jumusiq
Jumusiq's Avatar
The offset I think is 45. Is that considered aggressive?
Thanks for the help by the way.
Old 01-13-15, 07:51 AM
Dukeaudio
Dukeaudio's Avatar
My fnts are 9" et32 (about .5" less offset) on 245/35 and rub slightly but you should be good. Btw, if you are as particular as i am, the 245/35 Fnt tire won't be as stretched as 275/30. It will have a 'squared' (taller profile) look vs the rears slightly 'stretched' look (I'd expect slight variations between brands). Will change fnt set-up this summer.
Old 01-13-15, 08:47 AM
LexRuger
LexRuger's Avatar
That's pretty conservative. You could probably even use a 5mm spacer if you want it more flush.
Mount em up and see how they look
Old 01-13-15, 12:13 PM
ARISTOh
ARISTOh's Avatar
Well I have 20x9 +32 with 245/35/20 Michelin Pilot Siper Sports and 20x10.5 +45 with 285/35/20 same tires, both front and rear seem to have a very slight stretch and no rubbing at all with favorite suspension. I plan on putting RSR Down springs when I get them in the mail and I was able to get perfect alignment at factory height with the wheels. I have the SPC rear camber arms on order as well so when it's dropped hopefully I can keep these expensive tires as long as possible
Attached Thumbnails Need Help -- Recommendations for 20" rim tires?-image.jpg
Old 01-13-15, 12:19 PM
ARISTOh
ARISTOh's Avatar
Gender gap looks worse in pictures, but here you can see 285/30 on a 10.5 rear wheel fits nicely especially at stock height on a non FSport GS (Luxury package with AVS)
Old 01-13-15, 12:23 PM
ARISTOh
ARISTOh's Avatar
And a quick view of the front
Old 01-13-15, 08:09 PM
Jumusiq
Jumusiq's Avatar
Got em installed! Happy as can be!
Old 01-13-15, 09:16 PM
LexRuger
LexRuger's Avatar
Looks good. Congrats.
Old 01-14-15, 06:40 AM
Jumusiq
Jumusiq's Avatar
Thanks so much for the help. I was able to use the info you gave me to confirm what I was getting before they did the installation.
Old 01-14-15, 07:34 AM
Dukeaudio
Dukeaudio's Avatar
If I remember correctly, the RSRs aren't as low as the Tanabes, so you might not rub. Let us know how they work out for you.
Quick Reply: Need Help -- Recommendations for 20" rim tires?
