2015 GS350 Radio Volume Default
Got a question I hope someone can answer as I can't find a way to set it in my GS.
Every time I start the car and turn on the radio, enforum, etc. the volume is always at 22 which is LOUD. I'd rather have it start where I was before or set it 8 or 9. I've gone through the settings and looked through the manual, but don't see a way to set the volume.
Thanks
Thanks
Thats strange...my 2014 GS keeps the last setting that i have when i turned off the car. Whether that setting was 0, 22, or 45 its stays that way and also remembers different volums for different sources.
That's a new one for me too. My audio volume comes On at crank-up where it was last set.
I suspect the 'Setup' for 'Audio' may be something to look at.
Yes it is odd, though it tends to happen on enForum Pandora all the time even if I switch to XM or FM and then go back to Pandora - level goes right back to 22.
I'll be taking it to the dealer for the 1000 mile checkup in a couple of weeks so I'll ask them about it then.
New system glitch maybe? Cause I don't remember ever having that problem with the older system and never saw an option to change that. U can set the default volume for the phone and ringer but not the master volume.
I have the 2015 and mine doesn't do that. Instead when I turn on any media source, it keeps it at the same level it was last time i used that particular media source. Each media source has it's own volume level memory.
Sounds like its programmed to your key fob. It remembers a lot, seat, ac, radio station, SAT, mirrors, volume. lock your car, walk away, then come back with just the other fob. If you program a key fob with a seat memory button, it memorizes the settings for every thing else too. It makes it easy for his and hers settings that way.
Anyone know if there is a fix for or setting for adjustment for this default audio volume of 22 at start up? My 2016 does this for Pandora/ Iheart radio apps. It's annoying.
