Sudden loss of power
Old 09-19-14, 10:18 AM
SNiiP3R
SNiiP3R's Avatar
Default Sudden loss of power
As of yesterday the gas pedal started losing power completely. It only happens for a brief moment when I'm driving and only in the morning. The car does not shake, rpms don't drop and no check engine light. I'm not sure what's going on, I can't replicate it so going to Lexus is pointless at this point.
I was thinking maybe its my fuel pump going bad?
Old 09-19-14, 11:00 AM
DaSyce
DaSyce's Avatar
Pump gas recently? Bad gas? H2O leak into gas station holding tank?
Old 09-19-14, 11:21 AM
Afrosheen
Afrosheen's Avatar
Yeah I'd blame the fuel too. Did you put some 86 octane in it to save 5 bucks? Did you go to a station you normally don't visit? Has it done it before?
If the fuel system or fuel pump are having problems, the ECU is gonna throw codes. A temporary bog may be your car working around a spot of bad fuel and making an adjustment on the fly.
You may want to see if the dealer can drain the tank and refuel it. I don't know how else to eliminate a bad tank of gas as a variable.<Edit, throw a bottle of octane booster into that tank. If it goes away, you know what happened and which station to avoid.
Old 09-19-14, 01:01 PM
lazerlazer
lazerlazer's Avatar
That could be scary!
Old 09-19-14, 03:00 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
This car already has a delayed throttle response. Now a sudden power loss...
Old 09-19-14, 03:30 PM
SNiiP3R
SNiiP3R's Avatar
Yeah it could be the fuel, that's what I'm hoping for. Then again, I never put anything below 93 in this car.
When it happened yesterday I just ignored it, but today I tried flooring it, with no response.
Old 09-19-14, 06:57 PM
Dukeaudio
Dukeaudio's Avatar
To the dealership, ASAP...safety first.
Old 09-22-14, 12:56 AM
Afrosheen
Afrosheen's Avatar
Agreed. With 93 in the tank it shouldn't act like this.
Old 09-22-14, 09:54 AM
terrycs
terrycs's Avatar
I agree with the others. Fuel wouldn't cause such a drastic or sudden drop in performance. I assume you are not getting a check engine light either to indicate an obvious sensor failure.
I would still recommend taking it to the dealer as you car is probably still under warranty, especially for such a serious issue. The cars engine management system actually logs quite a bit of data that they might find to diagnose the problem.
Old 09-23-14, 06:39 PM
e325rkh
e325rkh's Avatar
Perhaps you were driving either a BMW, Mercedes, Audi or others before jumping into the Lexus? just kidding, wanted to beat the other trolls to it.
To the dealer....
Old 09-23-14, 08:22 PM
flippd
flippd's Avatar
Any updates???
Old 09-24-14, 05:15 AM
SNiiP3R
SNiiP3R's Avatar
Originally Posted by flippd
Any updates???
Not yet, I'm dropping the car off on Satruday. I was able to record a video, I want their techs to see it.
Old 09-27-14, 06:35 AM
SNiiP3R
SNiiP3R's Avatar
Dropped the car off today. Their master tech is not in today, so the car will be there until Monday.
and of course, on the way to the dealership it drove perfectly fine! <sigh> I hope on Monday the problem will come back, otherwise I'll get a broken car back
P.S.
Got the CT as a loaner... LOL this roach can barely move.......
oh and the video of course,
Old 09-27-14, 10:44 AM
islandbeef
islandbeef's Avatar
I had a similar problem with my 5 Series BMW, it was a bad cam sensor.
I did some research and discovered that this was common in the ES models. Perhaps, it came over to the GS?
Old 09-27-14, 10:48 AM
islandbeef
islandbeef's Avatar
Check out this thread from earlier LS models, the symptoms sound very similar to yours:
https://www.clublexus.com/forums/ls4...-of-power.html
Earlier GS models:
https://www.clublexus.com/forums/per...on-sensor.html
Perhaps, their remedies may be the same for the 4th Gen GS?
Quick Reply: Sudden loss of power
