will it rub?
Old 09-11-14, 09:45 PM
simonsez
simonsez's Avatar
Default will it rub?
i'm going down on J5 coilovers at about 1 finger gap and wondering if 245/35/20 fronts & 285/30/20 rears will definitely rub or not?
seems like i do have much more tire choices by going 245 & 285,
rather than 235 & 275. plus by going wider tires, i'll have more meat to protect the wheel.
Old 09-11-14, 09:47 PM
simonsez
simonsez's Avatar
teaser shot of the wheel - SSR MS3
Old 09-11-14, 11:57 PM
bigblack06
bigblack06's Avatar
your saying a finger gap I don't think you will rub anything lower than a finger gap you will rub as I did with that tire size.
Old 09-12-14, 02:38 AM
SNiiP3R
SNiiP3R's Avatar
Without knowing your wheel offsets, its hard to say if you will rub or not.
Old 09-12-14, 07:36 AM
DoriSaru15
DoriSaru15's Avatar
Nice wheels What is your specs on those wheels (size, width, offset, and disk)? It might fit but with out knowing your specs i cant really say.
Old 09-12-14, 08:10 AM
obturator
obturator's Avatar
Nice wheels. What color center caps did you get?
Old 09-12-14, 09:49 AM
simonsez
simonsez's Avatar
specs are 9.5 +35mm fronts / 10.5 +43mm rear
i didn't special order center caps. they came in as silver
Old 09-12-14, 10:10 AM
bigblack06
bigblack06's Avatar
If your not lower than a finger gap I wouldn't worry about rubbing, you could go with the 275 if your worried, you should be good though.
Old 09-12-14, 10:15 AM
simonsez
simonsez's Avatar
I wanna achieve this look.
This was my old car with 1 finger gap height. no rubbing issues with 245's and 285's
Old 09-12-14, 11:29 AM
obturator
obturator's Avatar
What tire brand r u going with?
Old 09-12-14, 11:48 AM
simonsez
simonsez's Avatar
hankook v12
Old 09-12-14, 12:46 PM
DoriSaru15
DoriSaru15's Avatar
What disk are you? SL, NR, MD, HP? if you are in SL and NR on the rears then i think you can go 285, but i would stick to the 275. If your fronts are SL, NR, and maybe just maybe MD you can go 245 if not you need to roll it.
Old 09-12-14, 01:50 PM
simonsez
simonsez's Avatar
MD fronts, SL rears.
thanks for your inputs. i'll stick to 275s for the rear and try both 235 and 245 for the front.
I'll keep you guys updated on this set up.
Old 09-12-14, 02:08 PM
neegroy
neegroy's Avatar
veryyyyyyyyyyyyyyyyyyyyyyy nice setup.
where in ny are you located bro id like to come see your car when its done lolssss
Old 09-12-14, 06:50 PM
SNiiP3R
SNiiP3R's Avatar
with those offsets in the rear and that drop, you might have to slightly pull fenders if you go with 285's.
I run 275's with +42, and I have just a few millimeters between the fender and the tire.
I don't have a better picture, so you can't really see how close it is, but this is my 20x10.5 +42 w/ 275's.
Quick Reply: will it rub?
