New Obsidian '14 GS350 Black Out
I applied 4 coats to the rear emblems and waited atleast a half hour between coats. When I peeled the Plasti-dip off, it also peeled off a few parts of the emblems? Any advice?
I did do pretty light coats and made sure to change the angle I was spraying with each coat. I've read that helps create the break between the body and the emblem.
My limited experience with plastidip tells me you should give it more time to cure before peeling off. I found that if you try to remove it too soon that it's too elastic to remove at important break points.
amerrival (04-02-24)
Well I went to get the spacers installed and apparently I got the wrong ones and it was turning out to be a much longer, complicated job... so I pulled the trigger on some new wheels instead. I moved away a little from the Blackout and I was reluctant when I ordered them, but it turned out awesome!
Vossen Bronze VFS-2 Front: 20x9 245/35/20 Rear: 20x10.5 275/30/20
GTGS350F (11-17-19)
@BrooksC - but blacked out tails just don't work for me - I just see too many crap cars with them. You need some contrast to really bring out the lines in the car.
@uhasib - I like it...
Which window tint is everyone using with Obsidian? I want the tint hue to match and not be too blue or anything...
Did you black out your calipers? Maybe gloss black would work?
