ML audio added after the fact 2014 GS FS Sport?
Old 06-04-14, 06:22 AM
roosta23
roosta23's Avatar
Default ML audio added after the fact 2014 GS FS Sport?
Hi,
Just curious in the rear case i was able to come across a ML audio system for a 2014 GS350 F sport, could it be added after the fact fairly easily due to it having more speakers?
Also Do the 2013 and 2014 ML audio upgrade have same part number for the FSport GS350???
Also any feedback to the system as i had the ML upgradein my 2008 GS350 and it was phenomenal sounding....The stock system in the 2014 gs F350 sport sounded pretty damn good on its own, i pick up my new whip in white tommorrow.
Thank you
Old 06-04-14, 07:29 PM
Afrosheen
Afrosheen's Avatar
I'm gonna go out on a limb and say it's not possible, and if it is, it would be prohibitively expensive to install. It's a factory build option, not a dealer install option, so that tells you it kinda needs to happen while the car is being assembled.
The ML system has 17 speakers. Count how many your car has. Consider the panels for each set of speakers, for each port on the rear doors, etc. Consider the wiring. Are all the GS's wired for the ML, or does the ML get extra wiring? Then there's the rear shelf that has 2 big speakers and a fairly large center sub, so the rear shelf may be another part number. The ML also has an 825 watt amp hidden somewhere.
I don't mean to discourage you, because the ML sound is very, very nice, but I've heard from non-ML owners that the factory default stereo is good too. I'd be surprised if they didn't share the same head unit but were firmware-locked depending on the ML option set.
Old 06-04-14, 07:43 PM
mdhaliwal
mdhaliwal's Avatar
The price of the ML speakers alone is outrageous - about $400 for a speaker!
Old 06-04-14, 08:51 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,050 Likes on 664 Posts
I thought all Fsport comes with ML?
Does the non-ML have a center sub in the rear too? I see the cover on mine but I don't know if there is a sub in there.
Old 06-04-14, 10:04 PM
sam430
sam430's Avatar
Should create a thread on differences unless it exists already. I do remember seeing bits and pieces of information scattered on this forum. There is different ohm rating for the speakers...different amp at same location. Extra speakers...probably doable but you would have to scour for the infor and consolidate it into one thread.
Old 06-05-14, 04:31 AM
obadea
obadea's Avatar
There are a few for sale on eBay. Speakers and amplifier and head unit. Should not be too hard to change.
Old 06-05-14, 07:41 AM
fsportjay
fsportjay's Avatar
Not all f-sports come with ML. when I was looking for mine, I saw a few that did not have it. deal breaker for me.
Old 06-05-14, 06:38 PM
Afrosheen
Afrosheen's Avatar
So if you can come up with the extra speakers (and if they are a different ohm rating you may need to replace them all), the last question is, what about the wiring? Are all GS'es wired for the ML system?
Old 06-06-14, 08:26 AM
95bat
95bat's Avatar
Received 1,349 Likes on 695 Posts
I don't think it is just the speakers are are different, I bet there is a different signal from the deck in the front as well, but I'm just guessing on that one.
For all the work you'd have to do to get the new speakers and amp in, you might as well buy aftermarket stuff and get the best sound possible.
Old 06-06-14, 02:21 PM
e39ng
e39ng's Avatar
Here's the comparison between Non-ML and ML system:
Old 06-07-14, 03:45 PM
Igor911
Igor911's Avatar
You have to special order the GS in order to get ML. I personally think it's worth it. Every time I get a loaner, I can def. notice the difference...especially when a song has bass.
Old 06-07-14, 05:41 PM
95bat
95bat's Avatar
I didn't special order mine and it has the ML package...
Old 06-07-14, 05:46 PM
ItzFilyO
ItzFilyO's Avatar
The GS Fsport I test drove had ML in it and so did the IS 350 Fsport, that's why I thought ML comes standard with Fsport models.
So mine is the 12-speaker one and still have a woofer in the back. Nice.
Old 06-08-14, 05:51 AM
Igor911
Igor911's Avatar
Here on the Eastern shore ML is not factory ordered for cars on the lots. Anyone who wishes to get ML will need to special order it. Not sure why Lexus decided to do that for this area
Old 06-08-14, 06:47 AM
SNiiP3R
SNiiP3R's Avatar
Lexus must think that people on the East Coast are all deaf, so ML is not required for this region. Lexus also believes that people on the East Coast cannot drive, hence the AWD is the only option available.
Quick Reply: ML audio added after the fact 2014 GS FS Sport?
