Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Fourth Generation
Sign in using an external account
Register Forgot Password?
Old 12-16-14, 10:54 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
Replacing GS350 4G standard Fog lights with LED
Thread Tools Search this Thread Display Modes
Old 06-19-14, 02:19 PM   #16
ItzFilyO
Trader Score: (0)
ItzFilyO's Avatar
Quote:
Originally Posted by ruger04 View Post
I recently bought the H11 30W XenonDepot LED Fog Light Bulbs from KBcarstuff.com. However, when I tried to install it, the bulb wouldn't turn in the housing to lock. I compared the bulbs with the OEM and they looked the same. When I looked on the back of the OEM bulb it was H16 bulbs. Does that make a difference in terms of fitting? OR should I look for H16 LED bulb? If so, where can I get them?
Quote:
Originally Posted by AL13NV8D3R View Post
I am pretty sure its h11 and not h16 but I may be wrong. Also check to see how thick the rubber gasket is on the new bulb, if they are thicker than the halogens it will take more force to install them because you have to compress the gasket before you can turn to lock.
It is an H16 bulb, it looks 99.9% like the H11 except that it's smaller and an H11 bulb wouldn't fit in an H16 housing. At first I thought it was H11 until I got a replacement bulb and it wouldn't fit.
Plus the wattage difference is quite big, H16 is 19W and H11 is 55W.
And there are 2 kinds of H16 bulbs, one with the clips on the side (5202/9009) and one that looks like an H11, so make sure u get the one that looks like an H11 bulb, not the H16/5202/9009.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
2014 GS 350 F SPORT RWD
2015 CT 200h FWD
ItzFilyO is offline   Reply With Quote
Old 06-19-14, 08:05 PM   #17
ruger04
Trader Score: (0)
I even took off the rubber gasket and yet the H11 bulbs wouldn't turn. I did research and only found the H16 bulbs that have the clips on the side. Can anyone recommend where to get H16 LED bulbs 5000k that have the H11 setup?
ruger04 is offline   Reply With Quote
Old 06-19-14, 10:57 PM   #18
ItzFilyO
Trader Score: (0)
ItzFilyO's Avatar
I think the H11 bulb is slightly bigger than the H16, just slightly and that's why it couldn't fit an H16 housing. But an H16 bulb can fit in the H11 housing.
__________________
2015 CT 200h FWD
Old 06-22-14, 07:22 PM   #19
ruger04
Trader Score: (0)
I was determined to figure out a way to fit the H11 bulbs in the OEM fog housing. This was what I did, if anyone wants to do this:
I had to remove the fog housing from the wheel fender side of the bumper:
1) turn the wheel in order to access the fog light housing (turn left to access the right side)
2) take out the 2 clips in the inner fender by using a flat head screwdriver.
3) take out 3 screws from the bottom bumper, 2 of them are attached with the splash guard.
4) pull the fender outward and pop the plastic cover near the wheel.
5) unplug the power source
6) with a philips screwdriver, take out the only screw holding the fog housing and remove the fog housing.
7) take out of existing OEM fog bulbs (H16)
8) the H11 LED bulb side tabs need to be adjusted slightly higher, using a plier.
9) place the H11 LED bulbs in the housing by slgihtly snapping it in, and turn clockwise to lock
10) place the OEM fog housing back in place and plug in the power source. (Test it first). Screw back in the bottom screws, and pop the plastic cover back in and put in the 2 clips.
I know this may sound like an easy job of just putting in the H11 bulbs in the OEM Fog housing but I couldn't fit the bulbs in without take out the housing. I found out if I had try to push in the H11 bulbs I may have broken the housing tabs as only one tab was held on with a screw. It was much safer to remove the entire fog housing then put in the bulbs safely.
These are the H11 30W 5000K LED Fog Light Bulbs. They look pretty close to the HID 4300K. However, after looking at the lights at night, the OEM 4300K HID showed a bit of yellow color compared to the 5000K LED (which were all white and a tiny tint of blue/purple).
Replacing GS350 4G standard Fog lights with LED-20140622_190602.jpg   Replacing GS350 4G standard Fog lights with LED-20140622_190628.jpg
Similar Threads
Thread Thread Starter Forum Replies Last Post
Replacing fog lights to LED question crwmlw ES350 (2007 - 2012) 4 07-27-14 06:46 AM
leds at the fog light xshurikx SC 400/300 2 01-03-14 12:53 PM
Replace left fog light in RX350. exmeaguy RX - Second Generation 2 07-05-13 10:06 PM
How to remove fog lights? Help! SlvrBulit GS - Third Generation 9 01-15-12 06:50 AM
LED Foglights? IronCobra GS - Third Generation 24 05-20-09 09:28 AM
Tags
fog, gs300, led, lexus, lights
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
