Offset and tire size..
Old 12-17-13, 05:56 PM
LIMS407
LIMS407's Avatar
Default Offset and tire size..
Looking to buy some 20s with tanabe springs and wanted to know what is the best offset and tire size to avoid rubbing..
From the search, 245/35/20 and 275/30/20 seems to be the tire size.
But with lowering inch with tanabe, not sure if i need to go 30 front and 25 rear...
Also, please chime in about offset as well..
Thank you...
Old 12-19-13, 10:54 AM
terrycs
terrycs's Avatar
The 30 and 25 you mentioned are typical spacer sizes for stock wheels, not offsets.
For wheel offsets, you can look here:
https://www.clublexus.com/forums/gs-...els-tires.html
I would also recommend contacting the owner to ensure there is no rubbing.
Thank you...
Old 12-19-13, 06:16 PM
0mghi2u
0mghi2u's Avatar
I have rsr coilovers not much of a wheel gap 20x9+35 245-35-20 and 20x10+35 285-30-20 had a lot of rubbing front and back but back I had to shave fenders and pull fender a tad and also had to cut some fender liner. For front nothing I can do rubs only on 1-5mph sharp turns on inner liner
Old 12-19-13, 06:32 PM
Jaked
Jaked's Avatar
Is the +35 your spacer or offset? I am looking to buy 20's also. I have rsr down springs and I def don't want rubbing lol
Old 12-19-13, 06:55 PM
0mghi2u
0mghi2u's Avatar
+35 is offsets
Old 12-19-13, 07:01 PM
1sWt2GS
1sWt2GS's Avatar
just a tip
if you are getting wheels might as well get the correct offset so that you dont have to run spacers.
Old 12-19-13, 11:03 PM
Jaked
Jaked's Avatar
What is the stock offset? What would you suggest?
Old 12-20-13, 07:35 AM
LIMS407
LIMS407's Avatar
Thanks terrycs...
Would offset 35 front and 38 rear work??
Old 12-20-13, 12:33 PM
terrycs
terrycs's Avatar
Thanks terrycs...
It depends on your wheel width too. Look at the attachment in the thread above to see what wheel specs others have used.
But note that RobertE is using those offsets and reports rubbing in the rear.
Old 12-20-13, 04:45 PM
RayG
RayG's Avatar
you can run 20x9 et 35 245-35-20 and 20x10.5 285-30-20 et 45 and with the Tanabe Springs , its money in the bank. NO SPACERS!!!!!!
Old 01-04-14, 02:12 PM
ntubeusa
ntubeusa's Avatar
Can u guys help? Sizes are 20x9 +38 front and 20x10 +40 Rear, good size ? Lower with Tanabe springs,thanks for the help
SilvaIS350
GS F (2016-present)
06-03-18 04:39 PM
JEFFOS69
05-14-14 08:12 PM
beauphus
Wheels, Tires & Brakes Forum
01-30-04 10:10 AM
Quick Reply: Offset and tire size..
