Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus: How to install HID Headlights (on your non-HID equipped 2IS)
Step by step instructions for do-it-yourself repairs
DIY: GS 350 F Sport Fog Lights Installation Guide, non-oem switch
#31
Anyone have any suggestion on how to tap that green wire? Everything is wired except for that. Thanks.
I went ahead and tapped the ignition (red). BTW, I did not see any improvement in output (led version). The only benefit (my fog) is improved presence of your vehicle. I may be looking at alternatives to this.
I may tap that green wire too if I don't like the AC. I just need to look up the gauge of that wire.
#32
Did the fog lights install a month ago...
Other Helpful Threads:
1. https://www.clublexus.com/forums/gs-...grade-kit.html
2. https://www.clublexus.com/forums/gs-...on-fsport.html
Parts used:
1. http://www.vleds.com/morimoto-xb-led-fogs-type-t.html (This LED fog lamp has some serious power. It could blind your eyes if you look straight into it.)
2. http://nigel-jdmparts.com/2013-gs350...-light-housing
3. http://www.ebay.com/itm/Universal-Relay-Harness-Wire-Kit-LED-ON-OFF-Switch-For-Fog-Lights-HID-Worklamp-/131349802011?hash=item1e950eec1b&vxp=mtr4. http://www.ebay.com/itm/H11-880-Female-Adapter-Wiring-Harness-Sockets-Wire-For-Headlights-or-Fog-Lights-/381061322004?hash=item58b9065514&vxp=mtr5. 4 #10 or #12 (forgot which one I bought) 3/4 inch screws from local store
6. 18 gauge wire - http://www.oreillyauto.com/site/c/de...1280&ppt=C0335
7. Fuse Tap -
9. Heat Sleeve - got a 8 foot and that was plenty. Cut and use as required
Before I ordered the parts I evaluated if I could do this myslef. Made sure I can access the area behind the bumper. Opened the hood and plastic covers and made sure I can run those wires as described in this thread. Made sure I can access the parking light power souce and found that was difficult. Anyways decided to order the parts and start the job.
When the parts arrived followed the steps posted by OP. However, the fog lamps I used was different.
The diificulty I had was tapping the power source. I tried and tried but ran an extension wire to the passenger side and tapped into the steering wheel heater fuse. This was only hot spot I found using multi meter when Pushed on Start Engine button. The problem here is if the engine is not started you could drain the battery. I'm yet to find an alternative power source.
The other difficult thing was running the wire through the fire wall into the cabin. Suggestion here is to using a long screw driver to pinch the rubber down and use other screw driver with somebody's help to push the wire inside the cabin..
Some pictures below.
Thanks for all the help from the club.
Parts used:
7. Fuse Tap -
Amazon.com : Lumision FAST Shipping* ADD CIRCUIT BLADE STYLE APS ATT LOW PROFILE MINI FUSETAP FUSE TAP + FUSE SET 5, 7.5, 10, 15, 20 AMPS : Car Electronics
8. Black electric tape to keep the cables tight 9. Heat Sleeve - got a 8 foot and that was plenty. Cut and use as required
#33
And yes, the hardest part of the install is tapping the green wire. Because space is so small in that area.
As for running a wire thru the firewall, just use a clothes hanger. Or a metal stick hard enough to penetrate a rubber seal, and at the same time bendable so you can direct it out the engine bay. Once through just tape your wire on the engine side and pull wire thru into the cabin. Put a little silicone or soap on the wire to make your job easier.
#34
Has anyone installed these fog lights on their 2015 GS350 F-Sport yet? I tried to install them on mine yesterday and I guess Lexus changed the reservoir on the '15 model because it basically blocks half the fog light area. I really don't want to have to buy a washer reservoir from an older year....
#38
#39
Received 1,064 Likes
You're the second person I heard of having this problem...
Seems the US spec washer bottle design change for MY15
~ Joe Z
#40
Does anyone know if the OEM fog lights from the luxury trim will fit in the garnishes ? I already have the OEM fog lights, but im doing a f sport bumper swap out, so i wasn't sure if i needed a new fog light housing....
#41
Yes, it will work just fine, but i would suggest a set of LED fog housings if you can afford it. About $150 from theretrofitsource
#42
#45
