Musty smell out vents on start up
Old 09-21-13, 06:43 AM
  #31
obadea
obadea's Avatar
I had the exact same problem. Then Lexus performed a TBS because water was leaking in the passenger side and the smell went away. About 1000 miles later, it came back. Let me know if you find a permanent solution to this problem.
Old 09-22-13, 12:06 PM
  #32
chiefguy
chiefguy's Avatar
I have the same problem....been having this issue all summer long....brought it back to the dealership twice already.....they replaced the "filter", but I'm still having the issue...quite annoying for a car in this price point.
Old 09-25-13, 01:44 PM
  #33
hypnotika
hypnotika's Avatar
Just got my car back from 10K and changed out the cabin filter. Still have the stink as well...not cool
Old 10-06-14, 05:03 PM
  #34
stevieb54
stevieb54's Avatar
So what has anyone done? I just had my 14 IS in and they tell me just to turn it on fresh air every time I shut the engine off. What BS if you ask me. Do these cars default to recirc mode, maybe they should change that. I cant believe this is what you have to settle for in an over $40k car.
Old 10-06-14, 05:16 PM
  #35
Received 2,519 Likes on 1,817 Posts
The dealer should do an HVAC cleaning for you under warranty. If they wont, just buy a can of HVAC deodorizer at PepBoys and follow the instructions...works great.
Old 10-06-14, 06:13 PM
  #36
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
Mine started doing this a few weeks ago but it goes away after a min.
Old 10-18-14, 08:26 AM
  #37
loewenberg
loewenberg's Avatar
i have a 2014 gs f with 3300 miles and the moldy smell is awful for 10 seconds. i understand about the recirc and condensation buildup but the 'auto' setting in a $60K car should deal with that, one would think. i will ask the dealer to spray their magic into the ventilation system when i have the 5k service. i think it's pretty lousy that it happens at all!
Old 10-18-14, 05:05 PM
  #38
GS250
GS250's Avatar
you dont have to switch to recirculate. turn off the aircon and hang on for 10 secs before turing of the engine. i am not sure why it works but mine never come back after i start doing this.
Old 10-18-14, 05:10 PM
  #39
jvinhj240
jvinhj240's Avatar
It's happen to be the coils just like home A/C , the water that left over create mold, mildew. To get into it some car require removing the dash, but some succeed with just spray while the motor in running. Here is links hope it helps.
Old 10-20-14, 08:19 AM
  #40
The Auto setting does deal with it, it deals with it by maximizing fuel economy. Its an unfortunate compromise.
They'll do a cleaning at 5k and it will be fine.
Old 10-20-14, 12:28 PM
  #41
islandbeef
islandbeef's Avatar
I got it and the wifey (with a sensitive nose) hates it.
The "F" in "F-Sport" stands for "FUNKY".
I sprayed Lysol into the vents while running (non-recirculation), helped a little but the FUNK came back.
Old 10-20-14, 12:57 PM
  #42
ItzFilyO
ItzFilyO's Avatar
The A/C in my 2011 Camry never had this smell problem and I've had it for 3 years. It didn't have the Auto settings and I just had it blowing to the front windshield and the feet area all the times. Unless the weather gets really hot that I need it to blow straight to the cabin, I always left it blowing to the windshield and recirculation off. Maybe this is why it didn't have any condensation.
I'm going to try doing the same thing to this car now and see if it goes away.
Old 10-20-14, 01:02 PM
  #43
williakz
williakz's Avatar
Not gonna work. To gain CAFE credits, Toyota/Lexus changed the AC system from normally fresh air intake to normally recirculated air intake (at all outside temps of 75F or greater). So blame it on the folks in DC; they're really the ones pushing your buttons.
Old 10-20-14, 01:05 PM
  #44
ItzFilyO
ItzFilyO's Avatar
But when u switch to windshield and feet the recirculation always turns off, allowing outside air to come in.
Old 10-20-14, 01:14 PM
  #45
williakz
williakz's Avatar
Auto turns off, not recirc mode I believe. I could be wrong, so please check it out yourself.
Ask your dealer to show you Tech Tip L-TT-0158-14.
Quick Reply: Musty smell out vents on start up
