Fog light on GS 350
Old 04-10-13, 12:01 PM
yardie876
yardie876's Avatar
Originally Posted by sam430
Hmmm... I wonder if an ls460 projector will fit in those fog housing. I wonder if its even a good idea to out projectors in a fog. Do you guys think it's okay to put a projector fog on high beam mode? It won't blind people like an HID would (at least I don't think it would because of the cutoff and low position).
Hmm good thinking. I was actually contemplating whether a set of projectors from the retrofit source woukd fit the f sport garnish. I'd love if I could get projectors down there.
Posted from ClubLexus.com App for Android
Old 04-10-13, 12:12 PM
onexcite
onexcite's Avatar
Originally Posted by axiom00
Hey faifai,
Which LED bulbs are you using?
Do you think these will fit? It has a bigger base and not sure if there's enough room.
http://www.vleds.com/bulb-type/drl-f...11-1-pair.html
It will fix. there are plenty of room for it.
Old 04-10-13, 01:09 PM
axiom00
axiom00's Avatar
Thanks! I'll order them when they're back in stock.
Old 04-10-13, 06:17 PM
faifai83
faifai83's Avatar
Hey faifai,
Yes. They will fit.
These are the bulbs that were used
http://www.ebay.com/itm/111003608953
Your bulbs will be very bright.
OEM bulbs are 55W
http://www.rapidtables.com/calc/ligh...en-to-watt.htm
Old 04-10-13, 11:02 PM
axiom00
axiom00's Avatar
Originally Posted by faifai83
Yes. They will fit.
OEM bulbs are 55W
Thanks faifai!
Old 04-11-13, 12:17 AM
LexusVet
LexusVet's Avatar
https://www.clublexus.com/forums/gs-...7-finally.html
check out pic on page 2 of fogs
i just put in vleds 5k led fogs pretty close match to headlights
Old 04-11-13, 08:44 AM
axiom00
axiom00's Avatar
Looking good!
How would you rate the light output? Brighter or dimmer than stock?
itzlikedat
07-19-16 06:30 AM
organa7
01-21-16 05:24 AM
Tec80
07-05-15 05:49 PM
VAISF
05-28-15 11:44 PM
wpbmed
ES - 5th Gen (2007-2012)
02-02-12 10:13 AM
Quick Reply: Fog light on GS 350
