Can our music system play DVD Disc with mp3?
Old 04-03-13, 09:14 AM
buffguy
buffguy's Avatar
Default Can our music system play DVD Disc with mp3?
I have the mark lev system and I was wondering if I can play DVD-R disc with mp3 burnt on it?
Old 04-03-13, 10:22 AM
Igor911
Igor911's Avatar
no, only standard CD
Old 04-03-13, 11:04 AM
bigblack06
bigblack06's Avatar
Yes it can play MP3!
Old 04-03-13, 11:58 AM
Igor911
Igor911's Avatar
His question was asked if it can play MP3 off of a DVD-R...and the answer is no, it cannot.
Old 04-03-13, 12:06 PM
sam430
sam430's Avatar
If not, i would suggest a thumb drive.
Old 04-03-13, 03:00 PM
buffguy
buffguy's Avatar
Thanks for the info guys. I was hoping for it to work on DVD because of the huge space to load mp3s on. I tested the thumb drive vs the CD and the CD was much louder and better quality. I guess I will have to go buy more CDs.
Old 04-03-13, 03:02 PM
HUSKERnKS
HUSKERnKS's Avatar
You might try a dvd. Best way to confirm is to test it.
Old 04-03-13, 03:54 PM
zicogold
zicogold's Avatar
I have a 64 G flash drive in my car. The music sounds great as good or better than a CD.
I buy my downloads from 7Digital and HD Tracks. May I suggest you consider buying from a vendor that puts a premium on source quality, 176kHz/24 bits music:
https://www.hdtracks.com/
Believe I don't work for these guys, nor do I have a career in the music industry.
Old 04-03-13, 05:34 PM
bigblack06
bigblack06's Avatar
My fault, saw MP3
Old 04-03-13, 06:26 PM
williakz
williakz's Avatar
Originally Posted by zicogold
I have a 64 G flash drive in my car. The music sounds great as good or better than a CD...176kHz/24 bits music
How does this work? Can the Lexus stereo or ML pull hi-rez and process it directly off the flash? Does it have to be in DVD Audio format? Is there any technical docs on Lex digital music processing? Thanks in advance for any guidance.
Old 04-04-13, 06:26 AM
bigblack06
bigblack06's Avatar
I don't think so, I have done it on a CD but it never worked on a flash driver. Unless there is a secret way, then I need to know.
Old 04-04-13, 06:29 AM
Igor911
Igor911's Avatar
In our cars, the audio settings (Bass, Treble, ect...) are controled and set differently per source. I would play with those....should all sound the same, if not better on USB devices
Old 04-04-13, 08:57 AM
buffguy
buffguy's Avatar
Oh, I didn't know that. Thanks again!
Old 04-04-13, 01:43 PM
buffguy
buffguy's Avatar
Just tested it, doesn't work.
I adjusted the settings for the USB source and now it sounds wonderful. Thanks again for the info. I'm going to be using a USB from now on. Awesome!
Old 04-05-13, 08:21 AM
zicogold
zicogold's Avatar
Willkz, I copied MP3 and MP4 format folders onto a folders on the flash drive. I then plug the flash drive in the USB in the console box. Then bring up the USB on the screen, if you click the album or folder item the screen will display all your album or folders on the flash drive.
I have not tried FLAC format as yet, does anyone know if there are issues playing FLAC format on the ML system?
BTW, Arcade Fire's Suburbs Deluxe album bought from their own site sounds absolutely fabulous in the GS's ML system. That is because I am a "modern man".
Quick Reply: Can our music system play DVD Disc with mp3?
