4GS Achilles Heel - The Tranny
Old 02-19-13, 12:47 PM
Received 2,521 Likes on 1,819 Posts
The 8 will improve the car no doubt...
Old 02-19-13, 03:53 PM
Rexus300
Rexus300's Avatar
In Sport + mode, the car does hold the gears when you press down and immediately release the pedal. Nothing to do with the tranny problem here. I have no issues on my GS. It feels alot better than the 7 speed on my BMW 5 series and 8 speed on my Audi A8.
Old 02-25-13, 01:12 AM
bdizfiz
bdizfiz's Avatar
This happens in all modes. It might need a reprogram, but we'll see.
As for the "anything more than 6" comments, yes, that's what was said each time about the next number of gears. The flaw in a lot of the comments here about "oh, then it will just keep shifting a lot and hunting with even more options to choose from" is that hunting isn't about the number of gears per se. It's about a poorly programmed TCM that can't find the right gear, so it keeps shifting around. You have to remember what "hunting" means. It doesn't mean shifting. It means shifting back and forth with potentially long gaps between shifts as it can't find the appropriate mathematical answer for the equation that tells it what gear to choose.
More gears means the gears are better matched to each situation. More gears means it doesn't have to hunt. for the right one constantly because it can just shift to the appropriate one since shorter distances between gear ratios means you're more likely to have a match for a given situation.
My last car was a Toyota and didn't do this. It had a CVT, though (Highlander Hybrid), but the gas Highlander I had before that didn't do it either, and it was also a 6AT. I'm pretty sure this can be improved with better programming, but it would also be helped by an 8AT IF and only if the 8 is a good one (per the point on the 8AT in the LS460).
Old 02-25-13, 12:55 PM
I wonder if your issue is more getting used to the conventional transmission after being used to the CVT than any issue with your unit.
I hate CVTs, but my wife was very used to the CVT in her Prius and it was a lot of adjustment for her to get used to a conventional auto again when we traded it.
Old 03-04-13, 02:05 AM
bdizfiz
bdizfiz's Avatar
Steve, that's a great point, and one I wondered about myself until that situation where the RPM were pulsing back and forth while in cruise control. I also just drove my wife's RX for 6 hours over 2 days on the highway, and didn't find the same situation.
Yeah, definitely a bit of CVT adjustment (like I went through when I stopped driving turbo engines after years of doing it), but I think there's more to it than that.
Old 03-11-13, 06:22 AM
JPC65
JPC65's Avatar
In Sport + mode, the trans does stay revved up when you accelerate and immediately release the pedal. I've seen it hang at 4,500 rpm for more than 5 seconds until normalizing. Some background on me - I worked in the business and discussed this with a service guy (friend that I worked with previously) who then went to ask the techs. All the techs agreed this was normal operation...unfortunately there's nothing to fix or adjust. They had heard it from other customers too.
I dislike the behavior, but, I guess it's something I'll need to deal with. For me, this ONLY happens in Sport mode.
Old 03-18-13, 02:05 AM
bdizfiz
bdizfiz's Avatar
That holding w/ a high rev def happened to me in Sport S+ mode the other day (should be the same as putting it in Sport in this case). It's actually a really bad programming since it makes the engine less responsive and working harder.
I needed to pass in an emergency situation, revved, and then the situation changed drastically, so I came off the gas, but the engine kept revving. Then I needed power again, and it just couldn't deliver despite sounding like it was given the high revs.
Old 03-18-13, 02:16 AM
natnut
natnut's Avatar
Was your gearbox set to manual or drive?
Old 03-25-13, 01:39 AM
bdizfiz
bdizfiz's Avatar
Drive. If it was manual, I'd override it and be done with the issue. That's how I solved it one time.
Old 04-01-13, 05:32 AM
JPC65
JPC65's Avatar
An update - the issue happened the other day and when it did, the trans held, revving at about 5,000 RPM. When this happens, it make the vehicle almost un-drivable. There's no way to accelerate until the the trans normalizes and downshifts. This is the same behavior as bdizfiz experienced. Frankly, it's unsafe. I've resigned myself to drive in normal mode until such a time that Lexus acknowledges the issue and does something to remedy it.
It's really disappointing as I love just about every other aspect of the vehicle.
Old 04-01-13, 05:59 AM
rjm
rjm's Avatar
I had a large transmission surge about a week ago when maneuvering in very heavy traffic on the freeway, It suddenly surged up to around 5000 RPM and stayed there. In my case, the cause was driver-induced when I accidentally hit the left shift paddle on the steering wheel. When I realized what I had done, I held the right paddle down to put the car back in Drive. I'm not saying this is what others have experienced. I just saying it happened to me and it surprised me.
Old 04-01-13, 06:19 AM
rjm
rjm's Avatar
Regarding the "need" for an 8-speed transmission in the GS, I was reading about the newly designed 2014 Stingray Corvette in the May issue of Car and Driver. The car has a 450 HP engine that puts out 450 LBS of torque. The car comes with a 6-speed automatic transmission. An 8-speed in the GS350 will be a great sales gimmick but likely won't add much in the way of performance or fuel efficiency. It will certainly add to the cost of the vehicle.
Old 04-01-13, 10:40 AM
tankton
tankton's Avatar
It has 450HP, even a 5 speed would of been fine - the engine would simply overpower almost any transmission gearing. Yet, Lexus, with only a ~380HP V8 chose to go with the worlds first 8 speed.
Old 04-01-13, 10:48 AM
Received 2,127 Likes on 1,379 Posts
because the 2014 stingray with its honkin' v8 and the gs350 with v6 are so similar.
Old 04-01-13, 11:12 AM
BarrettF77
BarrettF77's Avatar
The Vette has the power to muscle through any gear it is in. Take 150 HP away and it is a little different. Despite underlying business decisions, I just cancelled buying a '13GS. My parallel reasoning, I never truly fell in love with the 6 speed tranny in that car. My '13 RX F Sport with the 8 speed in real world driving is better. I never feel like the engine has to shift or runs out of gear too quickly. We can argue the fuel economy all day long and not get far. But I can tell you the 6 speed tranny DOES hunt more than the tranny on an 8 speed gearbox. If Lexus puts the 8 speed in the '14 F Sport like all their other F Sports have, then I think we will see a very different discussion thread taking place here where owners get to see first hand the positives OR negatives of the tranny. I think there is nothing but benefit by having more gears. IHMO at least.
Quick Reply: 4GS Achilles Heel - The Tranny
