DIY puddle light led
#151
Supplmenting with a undercarriage LED light strip
So after doing this with the Sylvanias for a while - I have to say I am still unimpressed. It is better than stock (which was so dim it was pointless), but nothing like the OP pics look like. I'll post some night pics tonight.
I could try out the VLEDs next, but doing the mirrors is a pain in the ***. So I don't want to do this unless they will be ridiculously bright. I am about to do under-side-skirt puddle lights instead just to get more light...
Would it be real difficult to tap into the puddle light wires to have the light strip come on when the puddle light does?
#153
I was thinking about installing a LED light strip under the running board to project more light. This would be especially useful when the mirrors are folded in and set to unfold when the car is started.
Try what you have in mind and share. Thanks.
#154
Great DIY writeup. Recently purchased a certified 2013 GS350 and wanted to replace the puddle bulbs and this was great help! Replaced with iJDMTOY LED bulbs and they look excellent. It took about 15min per side. Thanks for the DIY!
#156
Does anyone know if these flank style LED bulbs from Vleds will work?http://www.vleds.com/5k-4-hpf.html The bulb is size 194. I used them on my 2010 RX350 and they are great. I just want to make sure that they work on the GS350, as the LEDs are only one sided.
#157
Yes they work but don't face the ground directly - the socket isn't parallel to the road, it's slightly tilted so you don't get the full brightness of the bulb (It's described earlier in this thread). If I had it to do all over I'd get the omni bulb and save $$'s
#158
Thanks Renrutjw! I must have missed that info while going through this thread.
#159
First post!
Just got a '13 awd for the wife. Found this board and am now checking for neat mods to do to the car. Like this idea! Will tackle the trunk and reverse lights first and then follow up with the mirrors next.
Thanks for the writeup!
#160
Those Sylvana bulbs are expensive! I just paid $28 for two including tax. I went to 4 Walmart locations, two Autozone locations, and one O'Reily auto parts store before I found them. $12.99 a piece. I hope they are bright and I'm not disappointed.
#161
#162
You should have get this Philips for half the price and even better quality. Sylvania bulbs will burn out in a year or two with heavy use.
Amazon.com: Philips 194 Bright White Interior Vision LED light (Pack of 2): Automotive
#163
Great LED.
They work fine in the GS.I had them in mine.
I've used that bulb many times in the puddles.
Also use them in the door panels.
#165
Originally Posted by Sevn86
Ok I just took your suggestion and ordered them. I will go and return the Sylvania bulbs. Thanks!
Yes, it also bites the bulb socket is not perpendicular, but instead appears to be a 45 degree-ish rotation. I just ordered these and am really optimistic. Look forward to trying them after they float over from China:
Amazon: S&D 5pcs Canbus LED 5630 SMD Bulb Led...White...120-160LM
