Strange Noise
Old 05-22-14, 01:05 AM
  #61
GS250
GS250's Avatar
Originally Posted by Rexus300
Not the sub frame bushings. They don't tighten any bolts during servicing to be perfectly honest. It's just inspecting. I've been with the service team few times in the service bay and know this.
i looked back the previous service check list. that item was tick as "visually ok" but i do remember there was once it mentioned being tighten. will request them to do so next service although i don't encounter the noise mentioned here (touch WOOD)
Old 05-25-14, 09:42 AM
  #62
Kajn
Kajn's Avatar
Originally Posted by SimonGS
Stopped by the shop and they picked up the car, and saw nothing wrong underneath. played with the exhaust was all fine.. The guy at the shop said someone else came in with the same problem, they ended up taking everything apart and not finding anything, and told him to go to the dealership since the car was under warranty. It took the dealer 3 days to find out what it was.
Would love to know what it was?
Old 05-25-14, 09:47 AM
  #63
Kajn
Kajn's Avatar
I had that same loud poping sound at least 4-5 times since buying my 2013 GS350. I was coming off of a driveway curb from a business establishment when they occurred. That is wen the car front wheel is on the street and the back wheels are still on the higher side. It clearly scared me b/c it was so loud.
Old 05-25-14, 05:20 PM
  #64
slowlane05
slowlane05's Avatar
When driving slow, and hit little bumps it sounds like its a loose exhaust, or something metal is loose. The sound is coming from the drivers side. Does anyone know what it might be, or had the same problem? Really don't want to take it all the way to the dealer.
I have a 2014 F Sport and have the same problem. Doesn't happen over speed bumps, just rough roads. Sounds like my exhaust is loose. Went underneath and if seems tight, must be something under the front of the car. It's ridiculously loud, sounds like in in a hoopty
Old 08-17-15, 03:14 PM
  #65
sylvia
sylvia's Avatar
OK< I am not the only one. I have similar noise for 2-3 months from the back, both sides, First I though the trunk is full with loose things, I took everything out except the spare tire. Noise continues, changed one link bar, the other one was ok. Noise is still on. On bumps, uneven surface, on highway when I drive between 80-90 km/h, on left curve more than on right, when I release the gas . One mechanic thinks is most likely the back struts and car plates (boushings) . Can u please tell me is the strut and the car plate are together or separate (RX300 - 2001) can u see the condition of the struts or you have the take everything apart? And once you take them apart you have to change them that is what my mechanic is telling me.
BostonVP
04-23-11 09:00 PM
rxlex
RX - 1st Gen (1999-2003)
03-21-10 05:58 AM
ExTrEmE99
10-14-09 06:55 AM
SGMIS3
07-16-08 01:08 AM
messysc
SC- 1st Gen (1992-2000)
10-18-02 12:34 PM
Quick Reply: Strange Noise
