Hard body
#76
Today i did the front bonnet. i use Wolf's Shine & Seal first before applying the 1st coat. Damn already sweating like a pig! The Shine & Seal is a little difficult to buff off with a dry cloth. It's like it sticks on the paint! I have to damp the detailing cloth a little to remove the Shine & Seal! Bro if i follow ur steps ----> strip, wash, clay, IPA wipedown, i'm a dead man!!! But yes to get the best effect out og the Hard Body, this is the way to do it... But it's too hard work for me
#77
#80
it's not difficult. you do it the same way you would prep a car for a detail, but in the end instead of BF Midnight Sun or CG J97, you break out the Hard Body. if i did have a secret i would def share it with you guys. i only use straight line apps on everything i put on the car, i.e. QD, while washing and even drying... i'm afraid of the wax on wax off technique.
#82
Can anyone explain the chemical composition of Hard Body? Is it a polymer, acrylic sealant, etc? It is quite pricey and I am trying to perform a comparison but it is difficult when there is no information available that I can find.
#83
Yep, I was sweating too. I tried the hood and decided to skip that step. I wonder if it would make any difference. My whole car looks the same. I cant tell the difference from the hood to the rest. Enjoy. This stuff is ...addictive.
#84
the hood IMO is the easiest part. did you guys tape off sections? you can do the hood in either 2 or 4 sections. i used the 2 section method... 1 piece of automotive tape right down the middle. 4 sections would be even easier.
#86
here ya go...
Detailers Domain
http://www.detailersdomain.com
Phone number: 201-660-7010
55 Oak Street
Detailers Domain
55 Oak Street
#87
IPA and steps of applications
Several mention to use IPA = Isopropyl alcohol to wipe down. What percent to use? I have both regular rubbing alcohol which is 70% isopropyl and 30% water or the industrial grade 99.99% isopropyl that I use to clean electronic components. Will IPA remove previous later of HB? I think the 99.99% isopropyl maybe too strong.
I am hoping to receive the Wolf's Shine & Seal and HardBody this week and pickup my car next week. I told my dealer not to remove the white shipping vinyl or wash the car as I will do the detailing myself. Can someone see if following schedule and steps looks good. Any recommendation will be greatly appreciated. Because I live in a condo complex where there are no cover parking I need to schedule the multiple coat while the paint is cool and not at direct sunlight.
Day 1
Early Morning
- degrease the car by washing with Dawn (base on past Zaino experience)
- dry car
- apply Wolf's Shine & Seal
- remove Shine & Seal
- apply HB and remove after 15 minutes
- wait 3 hours apply 2nd HB coat
Late Afternoon
- apply 3rd coat of HB
Day 2
Early Morning
- most likely there will be some moisture dew build up on the car in the early morning. I will dry the car for sure if there are any moisture but do I need to wipe down with IPA?
- apply 4th coat of HB
- If time permits or I feel crazy enough to apply more coats on the rest of the day.
Thanks in advance.
Day 1
Early Morning
- dry car
Late Afternoon
Day 2
Early Morning
Thanks in advance.
#88
@ ChuH...sounds good to me, however i would wait 5 days before i apply a 3rd coat of HB. you want to give the first 2 coats time to cure to it's best. you can wash the car 24/48hrs after the first 2 coats. but you should use the Wolfs nano shampoo. any other soap no matter how mild it is will degrade the HB, i know i tried it. after the 5 days, wash her wipe her down with an IPA and apply 2 more coats of HB. i use 70% alcohol no cut and it's fine. but you can use 60/40 0r 70/30 alcohol and distilled water. smart water works fine. have fun tes make sure the car is completely dry before applying HB.
#90
