lane change blinker
#61
Don't push left turn signal stalk all the way down, just enough that would trigger the lane change blink. Then let back up.
#64
I would have taken one for the road.
#69
Give it a try - it's free to check what settings are supported by your car; you only have to buy the "Pro Package" in the app if you want to change something or do advanced diagnostics, or clear Lexus-specific (non-OBD2) codes from your car.
#70
Thx gkcmilner...worked perfectly.
#72
Guest
Posts: n/a
Yeah it still takes some getting used to...doesn't bug me anymore...
#73
Thank you for clarifying the instructions. Worked on the first try.
Just did this myself (5 blinks) and it took a few tries to get it right. The official procedure can be a little confusing to understand, and you have to do it pretty quickly as well. There is also a step they have listed in the middle that you can actually do before you start the time-critical portion, so it's easier if you do that first. I'm going to try to describe what I did in case it helps anyone:
1. Start with the car completely off
2. Use the rotary **** on the wiper control to set how many blinks you want. This **** has four positions:
- 1st (bottom) position = 3 blinks
- 2nd position = 5 blinks
- 3rd position = 7 blinks
- 4th (top) position = no automatic blinks
3. Hold the wiper lever in the all-the-way-up position, and keep holding it there
4. With foot OFF brake pedal, press the start button twice so the gauges light up (keep holding that wiper lever up!)
5. Continue to hold the wiper lever all the way up for 5 seconds or more (if you go too fast you will have to start all over!)
6. Let the wiper lever come down one position and hold it there for 5+ seconds (don't let it go back to the middle, just let it come down one position)
7. Hold with wiper lever all the way up again for another 5+ seconds
8. Let with wiper lever come down one position again, and hold it for 5+ seconds
9. Let go of the wiper lever. The right turn signal should flash once. If it doesn't, turn the car off and start again at step 1.
10. Briefly move the turn signal lever down 1 position and let go of it again.
The left turn signal should flash to confirm your setting, but not in the way you might expect. It will blink 1, 2, 3, or 4 times to match where you set the rotary **** on the wiper control, so:
- 1 flash = set for 3 blinks
- 2 flashes = set for 5 blinks
- 3 flashes = set for 7 blinks
- 4 flashes = no auto blinks
NickMayer (09-13-23)
#75
Bump.
Just did this again on my 2016 GS350 F-Sport. Worked like a charm. For whatever reason the Carista app does not show this option for my car. (Android OS with OBD2 bluetooth dongle)
