lane change blinker
Old 06-09-12, 10:28 PM
Room4Tu
Room4Tu's Avatar
Went to the dealer today for my first 5000 mile service and had mine switched to 5 bursts while they were at it. I've got to admit 5 bursts seems just right. 3 bursts was just too short for me.
Old 06-09-12, 10:46 PM
onexcite
onexcite's Avatar
Originally Posted by gkcmilner
I will try to post the instructions tomorrow. It can be done yourself (doesn't need to be hooked up to the TIS computer like most LPS).
It's kind of a silly process, just a series of moving the wiper stalk. I changed mine to 5, but then went back to 3. (In the LS460 it's in the vehicle customization accessed in the nav screen.)
I'm looking forward to the DIY blinker change. Thanks ahead.
Old 06-10-12, 06:27 PM
gkcmilner
gkcmilner's Avatar
Attached are the instructions.
Sorry it's so late, but I just got back in town.
The following 3 users liked this post by gkcmilner:
4GS350 (12-21-22), GNew2Lexus (06-22-21), tompass (09-22-23)
Old 06-10-12, 11:35 PM
onexcite
onexcite's Avatar
Thanks for the instruction.
I just don't get it why Lexus not built it to the menu setting just like the LS & LX.
Old 06-11-12, 02:06 AM
03LX470
03LX470's Avatar
LX has the blind spot monitor?
Old 06-11-12, 10:07 AM
LexusGSFGO
LexusGSFGO's Avatar
Great information. Thanks gkcmilner! It worked great. One question. What is the "same direction cancel function" supposed to do? Is this supposed to enable a function to cancel the normal turn signal by switching it in the same direction in addition to the opposite direction, which is the defaul? I could not get this part to work. Thanks again.
Old 06-11-12, 10:58 AM
ECL
ECL's Avatar
Does not work for me.
Old 06-11-12, 11:12 AM
LexusGSFGO
LexusGSFGO's Avatar
I had trouble at first too. Make sure in the first step you HOLD the position of the wiper in the off position while simultaneously hitting the ignition switch (twice if you are not starting the engine). Also note the difference between right/left "Lane change" and "turn".
Old 06-11-12, 11:51 AM
ECL
ECL's Avatar
I finally got it to work. My mistake was letting the wiper stalk return to the neutral position between maneuvers. Thanks!
Old 06-11-12, 12:34 PM
HUSKERnKS
HUSKERnKS's Avatar
Worked like a charm. Thanks.
Old 06-11-12, 01:16 PM
gkcmilner
gkcmilner's Avatar
What is the "same direction cancel function" supposed to do? Is this supposed to enable a function to cancel the normal turn signal by switching it in the same direction in addition to the opposite direction, which is the default?
You are correct. Instead of pushing the stalk half-way in the opposite direction (the default) to cancel the turn signal, you push it half-way in the same direction.
I haven't tried changing this since the default seems the most intuitive for me.
Old 06-11-12, 03:17 PM
drdigital1
drdigital1's Avatar
One more clarification: the procedure worked for me only when in step 5 I selected the desired setting on the wiper barrel switch before starting the entire procedure.
Old 06-11-12, 03:44 PM
ECL
ECL's Avatar
Not to hijack the thread, but is there a DIY way to make the key fob open the windows and sunroof?
Old 06-11-12, 05:59 PM
gkcmilner
gkcmilner's Avatar
Sorry, that will require a service tecnician to connect a Techstream computer to your car .
Old 06-11-12, 06:18 PM
varcity64
varcity64's Avatar
Thanks. I will give this a try.
Quick Reply: lane change blinker
