Remote Starter
Old 06-08-13, 10:54 AM
SNiiP3R
SNiiP3R's Avatar
It came with the car, so I can't complain. But to be honest, I've only used it a few times. I hate the fact that the car shuts off when you open a door.
Old 06-08-13, 02:05 PM
Received 2,520 Likes on 1,818 Posts
Mine came with the remote start, don't spend a dollar on it. The fact that it shuts down as soon as you open the door IMHO makes it worthless. We have it on the Jeep and use it all the time, the Jeep requires you to sit in it with the key present and hit the brake and start button and then it cycles over to normal run mode without the engine stopping. MUCH better system, better range.
Old 06-08-13, 05:03 PM
puckhead85
puckhead85's Avatar
For me that killed it was the fact it works like 2 feet. Whats the point of that? Anyone have an aftermarket?
Old 06-08-13, 06:50 PM
UKNOWME
UKNOWME's Avatar
Originally Posted by bnlexus
If you get this option, will you get a replacement or separate fob? I don't mind the engine shutting off I need the AC on to help cool the seat down. It's been getting hot. It takes me about 20-30 minutes to get home but the back of my seat doesn't seem to get any less warm. I'm not sure if it has something to do with the perforated seats but I don't feel this on the RX or previous vehicle. And the fan is working too or at least I hear the fan noise back there.
They use the existing fobs. You have to hit the lock button like 3 times and that activates the RS. We had it installed on ours but don' t use it.
Old 06-09-13, 12:08 PM
Splashman
Splashman's Avatar
I have it on my GS450h and don't use it either. The car shutting off upon entering just seems so counter-intuitive that it makes it useless. Especially because the range is not that great on the remote.
Old 06-09-13, 01:38 PM
praetor
praetor's Avatar
I can see the engine shutting down when you open the door would make it annoying but I wouldn't say it's useless. Remote start the car, have it cool/heat up. Open the door and restart the car. It's still as cool/warm as it was when you opened the door 2 seconds ago. Damn Lexus drivers are so spoiled. LOL
Range would be an issue though. I had an Avital remote start on my 2000 Camry and it ran flawlessly for 13 years. I could start the car from a few blocks away. I'll probably seek some aftermarket remote start as Chicago winters/summers can be brutal.
Old 06-09-13, 03:32 PM
But then you have to put the engine through two startup cycles which causes wear on the starter, etc. Plus...you have to walk out to it to start it because the range is so bad.
Old 06-09-13, 05:42 PM
praetor
praetor's Avatar
I concede that range is definitely an issue. Lexus says 80 foot range in clear space, this is what makes it useless for most people as 80 feet generally means 20+ feet in real world situations.
As for extra wear on the starter from an extra start up cycle, it's negligible. It is after all a Lexus. My 1991 Camry is still on it's original starter and so is my 2000 Camry.
Old 06-09-13, 06:26 PM
SNiiP3R
SNiiP3R's Avatar
it would've been much better if RS detected the key fob. If you enter the car without the key it shuts off, with key fob it keeps running.....
Old 06-10-13, 08:08 AM
bigblack06
bigblack06's Avatar
Originally Posted by crzyis
Any one have it?
Thoughts on what it would cost to have dealer install it?
Sewell has it listed for 286 which isnt a bad deal at all.
http://lexus.sewellparts.com/accesso...2013/5391.html
I have this and I consider this a waste, only reason I have it is because it came with the car. I think your better off getting an aftermarket one as someone said it shuts off once you touch the door handle.
Neoxagon
ES - 6th Gen (2013-2018)
21
11-01-19 09:37 PM
XLucifronx
07-09-16 01:51 PM
jcarlo
12
12-04-12 04:02 PM
JamesP71
RX - 3rd Gen (2010-2015)
10-26-09 07:31 PM
jabol
12-30-05 08:55 AM
Quick Reply: Remote Starter
