It's raining in my car
Old 12-29-14, 05:41 AM
MyGS3
MyGS3's Avatar
Default It's raining in my car
For the past couple of weeks in Georgia, we've experienced rain. Every time it rains, water starts to leak into my car. I've attached a picture to provide a visual. I'm not sure if my windshield is the problem or the pillar where I see the water. Has anyone experienced this before? If so, what did you do to remedy to situation?
Old 12-29-14, 05:58 AM
lowKut
NELOC Moderator
lowKut's Avatar
Could be your sunroof is clog. I had a similar issue with my daily driver (none Lexus). You might want to check into your sunroof drainage and have it clear & cleaned out.
Old 12-29-14, 09:00 AM
kene
kene's Avatar
I would guess sunroof rubber seals to be the culprit. OR rusted out metal beneath the sunroof rubber seal.
Old 12-30-14, 11:54 AM
MyGS3
MyGS3's Avatar
Thanks! I would've never thought about my sunroof. I thought it was either the windshield or whatever is underneath that pillar had a leak.
Old 01-01-15, 01:12 PM
AJBoston
AJBoston's Avatar
Before you go buying new seals, check the drain. Open the sunroof, and on both front corners you will see the drain holes. If those are clogged, you will get water in that location whenever it rains. The sunroof drain pipe goes right thru that pillar all the way to the ground. I had the same issue. I used a small electricians snake and pushed it thru. Tested it with a glass of water. All set.
Old 01-02-15, 11:39 AM
MyGS3
MyGS3's Avatar
Good ****! Thanks. I will try this weekend. I need to do it soon. It's been raining like crazy over here.
dgeffeney
CT 200h Model (2011-2017)
02-06-23 07:10 AM
Metlupass2
06-11-21 10:15 PM
thegrouse
RX - 1st Gen (1999-2003)
04-23-19 12:43 PM
bigegg
10-26-13 10:09 AM
nysupraman
SC- 1st Gen (1992-2000)
12-17-09 01:00 PM
Quick Reply: It's raining in my car
