2JZGTE V160 Swap now Speedometer doesn't work.
Old 06-30-14, 02:27 PM
UncleRico
UncleRico's Avatar
Default 2JZGTE V160 Swap now Speedometer doesn't work.
As the title says I started up my newly swapped engine for the first time last week. At first the speedo and rpm gauge wasn't working. After doing some research I did the jumper mod inside the cluster and that fixed the problem for the rpm's. However still no go for the speedometer. Im using a Tweaked engine harness and everything plugged right in to the V160.
This transmission is brand spanking new out of the Toyota box so I doubt its the sensor itself. So Im guessing some wires do not match up in the engine to chassis plug??? Does anyone have a pinout of the chassis side of the harness that leads up to the cluster? Or maybe this isn't even the problem.
Any suggestions?
Old 06-30-14, 05:07 PM
joewitafro
joewitafro's Avatar
My auto speed sensor 2jzge plug plugged right into my R154 with electronic speed sensor and worked gravy.
I am thinking he did the wiring wrong for the electronic speed sensor, This is the wiring for our body/car
Old 07-03-14, 08:42 PM
joewitafro
joewitafro's Avatar
Rico I confused your PM with someone elses thread, you were looking for pinouts too.. I think I might have the plug information. I definitely posted all of this already in my build thread on how I did everything when I did the transmission R154 swap.
This is the p1 connector I am talking about.. Pins 5 and 6 are for the neutral switch and according to the diagram below... Pins 4 and 8 go to the reverse light switch.. It doesn't matter what order you wire them, I connected the two wires from the R154 reverse lights and cut two red wires from the p1 connector from pins 4 and 8, ones red with blue center the other red with black center. I ran wires going from the two black wires (one with white center stripe) to the bottom clutch switch inside the car so when the clutch is depressed the car is in neutral, when its not... the car believes its in drive.
CatManD3W
SC- 1st Gen (1992-2000)
18
09-14-19 07:08 PM
Jetkillr
IS - 1st Gen (2001-2005)
02-07-12 03:38 AM
trufanatic
10-13-10 10:09 AM
ck90211
04-13-10 06:05 AM
tavarish
Performance & Maintenance
08-16-08 07:12 PM
Quick Reply: 2JZGTE V160 Swap now Speedometer doesn't work.
