Is it possible to replace power steering reservoir with out replacing pump?
Old 03-26-14, 01:38 PM
sabbates
sabbates's Avatar
Default Is it possible to replace power steering reservoir with out replacing pump?
The power steering pump on my 94 GS whines, and I suspect the filter in the reservoir is clogged, starving the pump of fluid.
I shopped around for a new reservoir, but everywhere I looked, the pump and reservoir come as a unit.
Is it possible to buy the reservoir by itself?
If not, has anyone posted a filter cleaning procedure? I've heard of using acetone and BB's, but no pictures.
Old 03-26-14, 06:09 PM
MyGS3
MyGS3's Avatar
Are you sure you need to replace the entire reservoir? Have you checked the O ring at the bottom of the reservoir? There is a possibility the O ring has expanded due to age, which is starving the pump. I had a similar situation where the O ring was bad. I found this out after the pump was already purchased/installed. Just my 02.
Tmhender82
04-03-17 03:20 AM
rick1987
09-06-15 07:05 PM
worldforgo
02-04-12 09:47 PM
ozzie
04-29-06 09:41 PM
Quick Reply: Is it possible to replace power steering reservoir with out replacing pump?
