Help! Please!
My over drive won't engage. Fuel gauge won't work either. On the old one that is.
New one. No Tachometer and no speedometer. CEL is on too.
I think I messed up the old one when I took it apart. Either under or over tightened the retaining screws.
If you replaced the bulbs they could just be in wrong. Also like 8 of the screws on the back plate are continuity to the main board so if they are too tight/loose they may not be getting proper voltage. Those are for the fuel and temp gauges if I remember right. Be careful as they are easy to strip. I put some dielectric grease on those connections.
Roger on the dielectric. I'll do that too.
I'll run the broke *** gauge and use my gps for speed until I repair my gauge.
No I never replaced the bulbs yet. I say I messed up on the screws on the circuit board.
What happened to that write up about changing the bulbs? I found the one in the sticky under the DIY but that's not it. I think deknick did it? It was a full write up on the disassembly of the gauges.
