Converting from Clutch Fan to Electric Fan
Hey guys!! My fan clutch is on its way out and the fan blades are in pretty poor condition which hasn't been a problem so far because it has been very cold lately but once spring hits and temps climb I am sure it will become a problem. So I want to convert to an electric fan set up!! Is there a bolt on OEM part I can use from a 2GS/Supra/IS300 or are there companies that make a set up for our cars? Also for anyone running a E-fan setup what are you using for temp control of the fans? I hope there is something out there because I think it would really clean up the look of the engine bay!! Thanks in advance for any info.
I don't know of a bolt up version but supra stuff is real close if you have a fab shop or any fab skills. Make sure you use quality fans like Spal or Fal. Do NOT use mishimoto fans as they do not move enough cfm to cool.
As far as temp control sometimes I'll run one key on power and one off the back up fan circuit that's already there. Sometimes that's not enough though.
Not sure I haven't bolted mine up yet but I laid it on the old radiator and if I remember right It was pretty close. I can't really remember if you could just drill the holes different or not. The shroud I got was like $600 and discontinued anyway but there are more available.
Replacing the oem clutch fan and fan is a cinch, 30 minute job, and avoid possible electrical hassles. If the car is running hot with the mechanical fan, there's another reason why. My $0.02.
man, 3 months ago I was trying to get rid of my fan and clutch from my imported 2jzge. I wish you would have asked then.
Please, please, please if you are not cramped on needed engine bay space, don't switch to the electric. The stock clutch fan setup does a damn good job of getting flow through. Plus it is very simple to change. I bought my new clutch fan a year ago for $50 on rockauto.com.
I thought about installing the electric fans, and running the wiring, until I did some serious research and found that the return on investment (time, money, labor, reliability, mean time before failure, probable causes of failure, etc.) for a stock 2jzge in which engine space is not an issue (no turbos or piping, etc) was not worth it.
I am only saying this because the simplest route is to replace stock with stock for this issue. But who knows, you may have plans for going all out with the engine mods and the electric fans may be a necessity for the future. In that case it makes sense to go electric. It really is all up to you.
Just my thoughts, & my thoughts are pennies on the dollar.
I do plan to do a turbo swap in the future but honestly at this point in time swapping to an electric fan is just for cleaning up the look of tge engine bay. My car isn't overheating I just hate the look of the clutch fan.
Yes that is true expecially with the sc400 I did a turbo set up and changetd to an electric fan befor the swap and had to put two of them oppisite sides one suck on blow wired up to keep from over heating and after the turbo I had to take out all the plastic in front of the radiator
Cant do that it gets too hot with it in there just fans because turbo temp... with out it stays just how it should it winter below 0 and in summer above 100 so im happy without it but evey car is diffrent so just knowing your car and experimentation is how you figure it out
