1993 gs300 car is running rough
just change the wires on this car, #6 spark plug wire was in bad shape, now it is still running very rough in drive, can any one give me some thing to check for. thanks
it has 250k, I got it from my sister-in-law and my daughter has driven the car since her last year in high school, she is now in her last year of college. I have change out the disbutor with used one a year ago. I have change out the wires before about two years ago. I have also change out the coil pack, it ran very good, until I clean the engine, and I have had problem with it every since, I don't want to tear this engine down. what do I need to do.
If you cleaned the engine compartment the distributor may have water in it. Remove the distributor cap to see if there is any water in there? If there is water in there use some compressed air and blow it out or leave the cap off to let it dry. Is there a check engine light on?
Might read a bit of this:
https://www.clublexus.com/forums/gs-f...or-issues.html
In the LS400 section:
https://www.clublexus.com/forums/ls40...capacitor.html
I do, but you will need to PM me and follow some steps.
old school guy, what is pm, just change the spark plug is running better, but still has a skip to it at idle, would still like to change the timing belt
Sleeper97
Performance & Maintenance
08-14-05 02:47 PM
