Engine Coolant Gauge
So i was driving down the freeway in traffic n constant stop n go after about a mile my coolant temperature gauge kept rising it even went into the red for a bit. so i was rolling along expecting my engine to blow a head gasket or something and nothing after a while it would go down to normal and if im in a stop n go it sky rockets back n forth from half to 100%
when im on the highway getting good air flow the gauge reads fine but its the stop n goes that make the gauge sky rocket as if its not getting enough cooling. im not sure wat the problem mite be i have no leaks but the engine gets really hot so im a lil confused as to what the problem mite be?
any bump steer in the right direction will be highly appreciated. perhaps one of you have experienced a similar problem?
somebody, anybody, HELP!!!!
was thinking of replacing that along with the water pump
Its wierd cuz after turning the engine off and letting it sit for 2-3 hours the engine is still hot ((Doesnt seem normal if you ask me))
i believe my buddy got that replaced when he did a major tune up while i was up state
hopefully i dont have a BHG. How much did that run you by the way???
Might also want to look at the fan clutch.....check it by (with engine off) trying to spin the fan blade counterclockwise by hand. It should have pretty good resistance to not freely spin....if it does spin really free....it probably is causing air-slip.....at the stop/low speed as you indicated.
so perhaps having no shroud is also affecting it???
Yes...the lack of a shroud will affect that....and the blade should have more resistance in counter direction...of course u may have a couple things goin on......thermostat....etc...if the gauge bounces while stopped at stp sign, sounds like sticky t-stat...
Yea hopefully replacing all that fixes the problem
also i was told since i have a bad cat there mite be restriction not allowing the exhaust to be released
imma try n diagnose it this weekend when i get the chance
96UCF20
13
06-12-16 06:07 PM
