Help! Speedo and tach needle lighting!
Old 06-11-13, 03:23 PM
nadude98
nadude98's Avatar
Question Help! Speedo and tach needle lighting!
I hope someone can help me with this issue or even maybe have a schematic for the gauge cluster. I just installed a new speedo and tach cluster from Lexus and I still have the needle illumination problem. The speedometer initially lit up on both ends and then flickered and then quit working while the tachometer never lit up at all.... if I pound on the dash a bit the speedometer light will flicker and come on for a min. but that is it. Also the speedometer is way off now. Any help or a service manual would be of great service!!!
Thanks for any assistance!
Oh it's a 94 GS300..... lol
Last edited by nadude98; 06-11-13 at 03:25 PM. Reason: forgot to mention what vehicle duh~
Old 06-12-13, 02:15 PM
nadude98
nadude98's Avatar
Bump da de Bump! Help.....
Old 06-14-13, 10:22 PM
Titten
Titten's Avatar
If the cluster is new from Lexus, it's defective, right?
Old 06-15-13, 12:42 AM
supra247
supra247's Avatar
Ive had this problem since I bought my gs about 5 years ago. ive learned to live with it...lol. good luck on fixing it.
Old 06-16-13, 09:43 AM
nadude98
nadude98's Avatar
I did not get the whole cluster assembly, the part I got was the speedometer and tachometer with the flat plastic panel. The fuel and temp gauges and the rest of the cluster assembly is original. I am not sure where the power for the dial led's comes from in the cluster itself but I believe the problem is somewhere in the circuitry, be it a transistor or ic... Because when everything is cold the lights work for a few seconds...... that is symptomatic of solid state devices starting to fail, as they get warm they quit working......
Old 06-16-13, 03:41 PM
Nixspeed
Nixspeed's Avatar
If you search on here there is all kinds of info about this. Very common issue. Send your cluster to lextech.org they can fix it and have a warranty for their work. They will make sure its not in the circuit.
93oneuzfe
SC- 1st Gen (1992-2000)
03-02-15 09:44 PM
boostvic
09-06-13 01:57 PM
RedSC
05-27-10 01:13 AM
gsowner88
09-19-08 11:33 AM
Quick Reply: Help! Speedo and tach needle lighting!
