Build Threads Details on Club Lexus 1GS owner vehicles
Luxury Performance: JZS161 motor & JZZ30 R154 5 speed swap
Old 07-26-14, 02:23 PM
  #121
DJ8684
DJ8684's Avatar
looks great man! Cant wait to see it completed!
Old 07-26-14, 02:27 PM
  #122
joewitafro
joewitafro's Avatar
Took it for her first test drive today with the exhaust disconnected. Wow! Hahahahah that is all for now
I replaced the ECU temp sensor and it made no difference in my idle, so I adjusted the set screw for idle adjustment on my throttle body and got it to idle at 500-600 when warm which is normal for a 2jzgte. I found out my brakes didn't work while trying to move it out of the shop, turns out the rear port on my car isn't even connected so I had to put a vacuum banjo at the top. Works now I will probably try to have an exhaust down pipe finished by Monday, but in the mean time a ****ty cell phone video for you guys :P
Correct brake booster spot:
Luxury Performance: JZS161 motor & JZZ30 R154 5 speed swap-9hyiapt.jpg
Fan blade didn't touch on my test run. I found the rev limiter too somewhere around 6500-6800rpm
Old 07-27-14, 11:48 AM
  #123
BoughtanIS
BoughtanIS's Avatar
man that fan is close. Great job so far!!
Old 07-27-14, 05:12 PM
  #124
joewitafro
joewitafro's Avatar
Yep but right now the fan isn't hitting, and its cooling good (temperature never raises above half)
Although I do plan on removing the studs on the fan clutch and having precision 1/2" spacers made (I need them to be equally balanced, this will be my next project after my exhaust) and installing bolts through the front of the fan blade.
Today I used 2.5" u-bends to make a down pipe, definitely a few pie cuts to be able to mock it up and tack it in place. I doubt my welding will be pretty but tomorrow I am hoping to get welded up and bolted on.
I changed the ecu temp sensor and it didn't do anything, but since I adjusted the screw on the throttle body sometimes the car starts up and only wants to idle at 3000 rpm and other times it starts up idling at 500. Definitely need to inspect more and figure that out.
Old 07-27-14, 08:43 PM
  #125
joewitafro
joewitafro's Avatar
Couldn't help but take some more photos of the setup today. I found out some information about adjusting the throttle body screw, this is my issue with my idle spiking occasionally but whether I can get it to idle perfect when I set it back to OEM who knows. Lets hope! I think i might have a leak somewhere or a sensor screwy. I found a list of toyota/lexus MIL codes so I will pull codes tomorrow and see whats up. I've heard that I can eliminate all of the transmission codes with the use of resisters so I will look into that more.
Thanks to Jason T for this 2jzgte vvti information:
Originally Posted by Jason T
Re setting JZS161 2JZ-GTE throttle body adjuster screw factory setting
Un plug the 3 sensors ( main is tps yes do this while running) you will have 1800/1900 rpm when this screw is set right (Aristo JZS161)
TPS plug =1 ecu told throttle plate position
Pedal position sensor =2 where you want throttle plate it to be
Throttle motor plug =3 where the ecu says the throttle plate should be
Adjust the screw to get idle with 3 sensors unplugged while running aim for 1800 / 1900 rpm idle
Pull battery terminal for 30 seconds
Re plug all three then reconnect battery
Using jumper wire / paper clip turn key to ON don't start hold gas to floor count to 10 ( this resets pedal position sensor )
Leave ignition on remove jumper wire / paper clip
Re start enjoy 750 rpm idle
Recheck codes
JZS161 Throttle body adjuster screw factory setting
Pretty happy seeing this I think the engine bay looks great with a VVTI
Interior looks rough but some day I'll have the carpets redone and put new leather in it. I did get this authentic decade old italian momo steering wheel in near perfect condition for a good price. I still need to get a shift boot back in the car, I think I'll try a local upholstery shop to find real leather because all the stuff on ebay looks like crap
Down pipe isn't pretty by any means, but I am using scrap 2.5" pipe from a project a long time ago that my brother did. My pie cuts and angles aren't perfect but I'm using a pneumatic cut off wheel and 110v lincoln wire feed. From my mock up it seems to fit pretty good but I will bolt it up tomorrow and see how it really sits lol
Old 07-27-14, 10:55 PM
  #126
Nixspeed
Nixspeed's Avatar
Research idle adjustment for vvti. Its a pain.do not mess with that set screw. It's all computer controlled.
Old 07-28-14, 12:42 AM
  #127
joewitafro
joewitafro's Avatar
I believe that is what I quoted in my last post Nix. It's the only information I can find that seems correct. I will try tomorrow, if not he has close up pictures I can get it close, but I still need to reset the system like he says so I will try.
Old 07-28-14, 02:45 PM
  #128
Nixspeed
Nixspeed's Avatar
Yeah I didn't read it all. Just skimmed it. I had to reset one but I don't remember the process. I've just seen people mess with the set screw trying to adjust it. I really hate that throttle body setup.
Old 07-28-14, 05:49 PM
  #129
joewitafro
joewitafro's Avatar
I got the down pipe welded up and bolted on. I didn't take pictures because my welder was acting up and I only got a few decent welds, it was giving me a lot of trouble but whatever. Its on! haha
I also had to re bleed the clutch but it feels good now, back to normal!
I started the car and unplugged the 3 sensors and adjusted the screw to a 1900 idle and turned off the car, unplugged the battery for a minute and plugged the sensors back in, then put the battery terminal back on and put a jumper into my diagnostics. Turned the ignition on and held the throttle wide open for 10-15 seconds and then I pulled the jumper leaving my ignition on and started the car. Right now it seems to start up sometimes around an 800-900 idle, and sometimes a 1300-1400 idle, kinda weird but its working a lot better than it was.
Last of all, I was driving home after getting a little gas and decided to try a 2nd gear pull, I don't know if I hit fuel cut but my throttle body went into limp mode and I lost all control of the throttle except the last 20-25% which allowed me to pull off in a safe spot, after switching my ignition on and off a few times I got it started and giving me a throttle response again. No clue why this happened!
Old 07-28-14, 07:33 PM
  #130
Nixspeed
Nixspeed's Avatar
Should have cold start enrichment and idle up. If your engine temps are low it should idle higher. Sounds like the pain in the butt way I got that other car.
Old 08-04-14, 02:40 AM
  #131
micah32
micah32's Avatar
My friend has a vvti 2j in his 350z. he went single turbo, and has the same cutting out problem. the 3 sensors need to read the same number in order for the ecu to be happy otherwise its goes in to the limp "safe mode". only option is to go stand alone and delete sensors. from what hes told me.
Old 08-04-14, 08:59 AM
  #132
joewitafro
joewitafro's Avatar
I definitely feel like this is a fuel pump issue. The car boosts and will even rev out unless i go WOT which in turn its cutting out around 6k rpm and going into limp mode.
I suspected this initially but had to reset and drive it around to determine it but because I am using my stock GS300 fuel pump it does not flow enough (obviously) for the stock setup. My car is cold start idling perfect, I haven't tried the A/C yet because my system is still empty but when warm the car starts up at about 1100 rpm and drops down to a nice 800-900 idle every time now. Definitely seems like my reset did it and the ETCS-I appears to be working well. I am happy that it fuel cut and went into limp mode, I definitely appreciate that it didn't lean my car out!
Old 08-05-14, 05:15 PM
  #133
joewitafro
joewitafro's Avatar
got about 500 miles on the motor, from 80 degree weather 100 degrees the temperature doesn't move from the half way mark on my gauge. I know our gauges aren't the most accurate though... But I still have adequate water in my reservoir and I I don't notice any smoke burning from my turbos (YAY!)
I am going to do an oil change to get the high detergent 15w40 delo 400 out of it, the oil still seems really clean so the inside of my motor must be pretty good, but I will change it anyways for something better. I still have a couple oil leaks to fix but requires a bit more maintenance when I tackle that deep into the front of the motor.
Old 08-08-14, 07:15 PM
  #134
ClarkKent
ClarkKent's Avatar
Wow Joe so impressed. Super happy for you and don't worry about that interior... plenty of time for that later. and it's just nickle and dime stuff.
But that engine looks and sounds Awesome! Great Job! Now I'll go sit and pout with jealousy....
Old 08-12-14, 01:48 AM
  #135
joewitafro
joewitafro's Avatar
Just put another 500 miles on the car. It drives great, I do need to do the fuel pump which I will be doing soon. Just need more money! Haha
Kent you got some of the craziest SC/GS/Supra guys in Florida man, you need to start on a crazy build yourself
Quick Reply: Luxury Performance: JZS161 motor & JZZ30 R154 5 speed swap
