2005 Lexus GS 300 brake light problems
I have a 2005 lexus gs300 right hand brake light is out/imp,failure light indicator working in car. Have changed bulb and check the others. The left side works ok. Any ideas or help? I have red past post but could not find much to work.
Thanks
Thanks
Ok...your post is not too clear. I think you are saying the warning light is on and you changed the bulb, but the light is still on? If so, the tail lights have filaments. That means if you turn your lights on they will light up, but if you apply the brakes they or one may not light up. Also, check the third brake lamp and trunk lights.
FYI.....you are in the wrong section. There is a 2nd Gen section. This happens to be the 1st Gen section
Malo67
07-01-10 05:08 PM
SethP
RX - 1st Gen (1999-2003)
12-20-09 09:04 AM
