Antenna replacement?
Old 01-08-12, 06:07 PM
m1k3yg
m1k3yg's Avatar
Default Antenna replacement?
My antenna's broken ever since I got it and I don't know where I could get a replacement one that's not motorized, little help guys?
Old 01-10-12, 07:15 PM
2jzforme
2jzforme's Avatar
I bought a mast off ebay and tryed to put it in. Worked for 1 day and the plastic cord broke. Im preaty sure i did everything right, just a poorly made part. Stuff like that on ebay is expected. Im not sure if u can get a replacement mast from the dealer, probely $$$ if they do still offer it. Hope this helps.
Old 01-10-12, 08:50 PM
CallmeQ
CallmeQ's Avatar
You could always retract the mast back in the fender and get one of those amplified antennas to stick up high in your back window. A friend of mine did that with his LS
Old 01-11-12, 05:04 AM
m1k3yg
m1k3yg's Avatar
Well I could retract it if it was still there but it's completely broken off, and the motor doesn't work either, I saw a couple replacement ones at autozone but none of them looked similar to the current one
Old 01-11-12, 11:07 AM
Stolen
Stolen's Avatar
You could use any universal ant. just find one tht comes w a couple of differant mounting cups so it sits straight on the car. Then just unplug the main ant. wirefrom the power ant asem. and plug into the universal one. Or u could get an amp. One tht sticks in the window tht does the same thing , you could then have the ant hole shaved and filled by a body shop, for a cleaner look...hope this helps...
cjs18
09-11-10 11:00 AM
BlackRX
RX - 1st Gen (1999-2003)
02-17-09 07:12 AM
olddog
02-07-06 07:17 PM
cleoent
25
12-06-04 05:22 PM
delslo
11-02-03 10:45 AM
Quick Reply: Antenna replacement?
