Been Dancing around posting this...
Old 11-04-10, 08:16 PM
rapollon
rapollon's Avatar
Default Been Dancing around posting this...
Here's a riddle: what do you get when your car has a vibration that resonates throughout the car, but stops when you coast in neutral?
Old 11-04-10, 08:24 PM
VIP_Dreamz
VIP_Dreamz's Avatar
check your driveshaft? exhaust piping?
Old 11-05-10, 06:32 AM
dadewi
dadewi's Avatar
Rapollon,
I am having the same issues right now!!! I was told to do the neutral thing to. My mechanic told me it was my motor mount if the vibration went away while coasting in neutral.
Old 11-05-10, 08:54 AM
GoFastTSI
GoFastTSI's Avatar
Probably transmission mount, but could be worn motor mount(s) as well.
Old 11-05-10, 08:59 AM
dadewi
dadewi's Avatar
Is there any way to distinguish between the two?
Old 11-05-10, 11:38 AM
rapollon
rapollon's Avatar
I'm hoping its the tranny mount, but not likely. Most def don't want it to be the driveshaft. The differential has 4 mounting points, which I'm sure are worn after 220k+. Its not wheels and tires, since I've had 4 sets. I'll try the tranny mount first and post my findings. X my fingers...
Old 11-05-10, 11:39 AM
rapollon
rapollon's Avatar
I read somewhere you can put a wedge in the suspect mount to give it some pressure, drive it with the wedge in place and see if there is a difference. It's too cold out here for me to try, but its a good idea. Also, you can sometimes tell which are bad because the will clunk under normal use. I'm think mine is the tranny since I get the clunk during R and D shift change. I'm sure the motor mounts are shot too.
Old 11-05-10, 11:53 AM
mex lex
mex lex's Avatar
Originally Posted by GoFastTSI
Probably transmission mount, but could be work motor mount(s) as well.
Thats my guess, engine, trans, or diff mounts, or even the driveshaft. Have someone sit in the car and go from P to N to D, etc while braking and see if you can see anything shifting or moving under there. Pay attention to the diff, trans, driveshaft, etc
Old 11-05-10, 06:56 PM
Kaiser
Kaiser's Avatar
The rubber couplings between the driveshaft pieces can get worn out.
Old 11-05-10, 08:28 PM
rapollon
rapollon's Avatar
Thumbs up
Good Point... waiting for access to an engine lift
Old 11-07-10, 07:35 AM
afracer
afracer's Avatar
The tranny mounts on these cars is fairly soft rubber as are the motor mounts especially as they get up there in mileage/age. It may or may not be the mounts. Could be anything in the driveshaft, rearend or wheel bearings. We've had a similar vibration since we've owned the car for 3 years, let us know what you find.
Old 09-19-11, 08:38 PM
rapollon
rapollon's Avatar
Turned out the be the tranny mount
Old 09-19-11, 10:54 PM
m1k3yg
m1k3yg's Avatar
Mine does the same ish since I got it, tranny has to be bad though, I shift from p to d and BOOM whole car shakes, and when im braking while going downhill the shifter shakes back and forth
Helogadget
06-19-15 02:05 PM
rome99LS
91
07-18-14 06:32 PM
GS4TEK
07-14-12 11:53 PM
TLsc300
Performance & Maintenance
06-11-12 06:11 PM
scviolence
SC- 1st Gen (1992-2000)
07-10-10 09:43 AM
Quick Reply: Been Dancing around posting this...
