lower control arm bushing trouble
Old 04-13-10, 10:43 PM
VIP_Dreamz
VIP_Dreamz's Avatar
Default lower control arm bushing trouble
I have a 94 Lexus gs300. So I needed to get the lower control arm bushings replaced. I found some on ebay...only to find out the bushing does fit but the hole for the camber adjustment bolt won't fit.
http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
don't buy that bushing if you were planing too. don't fit for ****. damn packaging even says its for a 93-97 gs300 but they don't work.
was wondering if anyone on the forums knows where I can get the right part that will fit? or would going to the stealership be the only option? I know the dealer would probably sell me the whole arm with bushing.
basically this is the bushing for the radius arm aka the 2nd piece of the lower control arm. yes who would of thought the lca is a 2 piece?
does anyone know if that is the right part number? that's basically the part I need to replace, but I want to make sure that is the right oem part.
Old 04-14-10, 12:50 AM
TheMole
TheMole's Avatar
Sucks that the ebay ones didn't fit as even the diagram in the auction shows which bushings. Did you e-mail them about the issue? If so, what was their reply?
Which number in the diagram below is the part you are looking for? Number 9?
1) Steering knuckle Left
2) Upper cntrl arm Left
3) Upper cntrl arm Bolt
4) Front lower arm Left
5) Bushing Bushing Back
6) Ball joint Left
7) Adjust cam Front
8) Adjust cam Rear
9) Rear lower arm Left
10) Cam
11) Shock absorber Back
12) Lower bracket Lower bracket Left
13) Spring Left
14) Bumper Back
15) Upper insulator Back
16) Mount bracket Back
17) Upper support Back
Old 04-14-10, 01:23 AM
hipresr
hipresr's Avatar
I found this out the hard way to after pressing them in. All i did was drill out the center to fit the cam bolt and you will also have to machine off some of the thickness because they are too tall to fit in. Factory was like 36.5mm and the ebay are 45mm....
Old 04-14-10, 12:12 PM
VIP_Dreamz
VIP_Dreamz's Avatar
yea exactly part number 9 in the diagram. hipresr. I had asked my mechanic if we could just drill out the center a bit to fit the bolt. he made a good point. don't want to drill it since if there is to much play in the bolt, it can get stripped or loose. I rather get the right part, instead of risking it with some aftermarket part again.
Old 04-14-10, 05:18 PM
TheMole
TheMole's Avatar
That second ebay link you provided in the first post has the same part number as #9 in the diagram above.
Left: 4867030140
Right: 4866030140
Old 04-14-10, 10:49 PM
VIP_Dreamz
VIP_Dreamz's Avatar
ahh thanks a bunch. yea the guy selling the bushings on ebay claims to have sold over 500 bushings with no problem. what ever. total bull ****.
Old 05-06-10, 01:15 AM
Los2187
Los2187's Avatar
I am having the same problem with my car. To be clear, is the "radius arm" the same part as the rear lower arm (#9)? Also, came across this bushing, might this be worth it?
http://cgi.ebay.com/ebaymotors/93-97...item5ad387ffaa
Old 05-09-10, 11:15 PM
VIP_Dreamz
VIP_Dreamz's Avatar
los don't think that is the right bushing. there is a guy selling oem radius arms on ebay for 125 a piece.
Old 05-17-10, 03:07 PM
Los2187
Los2187's Avatar
Thanks VIP I was afraid it wouldn't be, I'll have to check out the whole arm.
Old 05-17-10, 06:26 PM
VIP_Dreamz
VIP_Dreamz's Avatar
yeah I got my radius arms from ebay. or contact the person at sales@toyolexparts.com. got both radius arms plus shipping to sf cali for under 300. the part numbers are 48660-30140 and 48670-30140. OEM numbers.
Old 06-15-10, 03:50 PM
mkiiisupra
mkiiisupra's Avatar
Are these only for the main arm (arm #1) or is this the main arm and radius arm for both sides. Doubt it since I only see 2 sleeves
http://www.toyheadauto.com/Performan...1990_to_111994
http://toyheadauto.com/PerformancePa...ics/3162K.jpeg
Old 06-15-10, 10:07 PM
VIP_Dreamz
VIP_Dreamz's Avatar
I just got the OEM arms off ebay. got them replaced already and damn does the car drive so much better. no more dipping while braking.
Old 06-18-10, 12:10 AM
KurtKnight
KurtKnight's Avatar
I just installed these, perfect fit!
Link-> http://stores.ebay.com/mybushings_Le...34Q2ec0Q2em322
They have the radius rod bushing even if it isn't listed, just send them a message very nice people to deal with.
Old 06-18-10, 09:50 AM
Mr. BRM
Mr. BRM's Avatar
I got my passenger side from these same people on ebay but during install yesterday the bolt broke that goes through the bushing. does anyone have a part number for it.
Old 12-02-14, 07:50 PM
Huicho
Huicho's Avatar
I need to replace both bushing for both control arm. Anyone one know if this brand will fit or is the same ones you got from eBay?
Quick Reply: lower control arm bushing trouble
