Clear 1st Gen GS300 Headlight Lens
#48
their lenses aren't as "clean" as you think.. u trim your headlight's flat spot off and leave a little edging.. THEN you glue the new one over it so theres a little trim around the whole
thing on the edge.. its the only path available right now but its not as clean as you think..
#51
just get a clean set of aristo ones and have them de-lined..
it'll be 300 on top but it'll be an oem headlight lens.. so it'll fit
perfect..
here's a picture of mines after i put in some LED and a retrofit..
perfect..
#56
yup imported from the UK and made with glass so no chance of it turning yellow/fogging up and fits the same as usdm/jdm gs's
#59
I sanded my lenses clear,(well 3/4 clear) and retrofitted Acura TSX projectors into them. Seemed to have turned out pretty decent, only thing I would change, would be the clear coat polish i used. I want to bake them apart and get them sprayed clear at a body shop for added "clearness"
