removing antenna?
Old 03-19-09, 03:51 PM
hash
hash's Avatar
Default removing antenna?
K i ****ed my antenna up so Im removing it completely. I got the motor for it off and un bolted, and all the wires unplugged etc. But the only thing that is holding it in is the antenna itself, I pushed the antenna all the way down through the hole at the back of the car. But in the trunk, I dont know how to disconnect the tube thing the antenna goes through from the top of the trunk.
Help grealty appreciated once again.
Old 03-19-09, 04:40 PM
AaronStaub
AaronStaub's Avatar
Can't make enough sense of your post to offer help.
Old 03-19-09, 07:17 PM
hash
hash's Avatar
Sorry I typed it up as fast as I could.
K, so on the inside of the trunk, theres the small electric motor for the antenna. Theres the motor part, and then there is a metal tube that has the mast in it that runs up and goes through the ceiling of the trunk. My question is, how do I unhook that from the ceiling of the trunk?
if you still dont understand ill stop being lazy and take pictures.
Old 03-19-09, 10:01 PM
BLAZE
BLAZE's Avatar
Just unscrew the top of the housing. I use a special tool, but you could use a pair of pliers or vice grips.... even a flathead screw driver. The idea is to unscrew the top chrome (or gold) mast. Then u could drop it down into the trunk and replace. Go for it, it is not hard at all. It is the piece with 4 indents in them. Turn it counter clockwise.
Old 03-19-09, 11:02 PM
Duds
Duds's Avatar
I use two flathead screwdrivers so I don't scratch the chrome.
Lveyolfe
SC- 1st Gen (1992-2000)
11-30-15 07:48 PM
ShawnOk
12-10-13 09:23 PM
SSAstro
02-24-13 08:18 PM
92Es300 5sPd
08-29-02 03:46 AM
Quick Reply: removing antenna?
