air bag light on?????
Old 11-22-08, 08:23 AM
lanthern22
lanthern22's Avatar
Unhappy air bag light on?????
Hello everyone im new to this site i recently removed my dash cluster and turned the car on! now my air bag light wont go off, i tried disconnecting the battery and that didn't do anything does any one know how to get rid of the air bag light on? thanks
Old 11-22-08, 02:08 PM
deknick
deknick's Avatar
tehre is a DIY guide under the tech section on clubaristo.net
i suggest signing up and having a browse through there. you have to connect speaker wire in a couple diagnosis ports, and then do something with the battery. I'll let you read it so something isn't misinterpurted
Old 11-22-08, 09:28 PM
1stGS30
1stGS30's Avatar
same **** happend to me!
Old 11-23-08, 01:23 AM
deknick
deknick's Avatar
it will always happen. if you have a look at hte DIY's that i have made, i've made a post at the top warning about this.
as long as you put the key in the ignition(even to move the steering wheel) while the gagues are out, you will get the airbag light coming on.
Old 11-23-08, 09:59 AM
lanthern22
lanthern22's Avatar
thanks a lot that was really helpfull!!! i have a 93 and love it just got it not to long a go.
Old 11-23-08, 10:05 AM
deknick
deknick's Avatar
have you had a look on clubaristo for the DIY guide on how to remove it?
Old 11-23-08, 10:17 AM
platinumac
platinumac's Avatar
doesn't that mean there is actually no air bag? i just saw that on the news around here...
Old 11-24-08, 07:46 PM
lanthern22
lanthern22's Avatar
Thanks a lot guys i was able to reset my light!!!
Old 02-14-09, 08:51 PM
tim8oland
tim8oland's Avatar
Hey CL, My airbag light popped up when I recently had the speedo fixed by Lextech. I know it's because I put the key in the ignition with no speedo attached. I did the reset, and now the airbag light keeps flashing. is this normal?? i tried doing the reset thing again, and it's the same result. how do i get it to turn off completely?? any help??
Old 02-15-09, 06:32 PM
tim8oland
tim8oland's Avatar
cmon now peeps...any advice on how to get the flashing airbag light off?? read above. i tried to reset the airbag light and now it's flashing after performing the reset. any help??
Old 02-16-09, 10:21 AM
1stGS30
1stGS30's Avatar
i think you might need to leave the battery disconnected for a lil while then try again
Old 02-17-09, 08:16 AM
RX469
RX469's Avatar
What did you do to reset it?
Old 02-17-09, 01:49 PM
tim8oland
tim8oland's Avatar
i actually did the TC,AB,TC,AB....trick to the negative side of the battery. The light went from being on constantly, to now just flashing. I'm going to disconnect the battery today for an hour and re-attach to see if this does the trick. any other ideas??
Old 02-17-09, 05:04 PM
Lexatlast
Lexatlast's Avatar
air bag bulb delete/removal?
i removed mine cause it annoyed the bejesus out of me. I did all the things talked about in this thread and others, but it just stayed on or flashing.
air bag is still functional.
Old 02-17-09, 05:26 PM
tim8oland
tim8oland's Avatar
--->This will be my last resort. If nothing else clears the light, then I will do the air bag bulb delete/removal too.
Quick Reply: air bag light on?????
