air bag light on?????
Mine just came on yesterday after a new cluster was installed. I remembered there was a post on Lextech.Org.
here is the link, I will try this tomorrow.
"WARNING: this manual fix should only be attempted if you are absolutely certain that the airbag warning light was tripped by a code 22 error. A code 22 error occurs when the ignition is powered up without the gauge cluster plugged into the wiring harness (starting the car without the gauge cluster in place). The brain runs a diagnostic check and does not receive feedback from the airbag, causing a fault. If this is not the reason your airbag warning light is on, then it is strongly recommended that you do not perform this fix"
http://lextech.org/forums/index.php?...8691&topic=9.0
RWC SC400
SC- 1st Gen (1992-2000)
48
01-06-21 06:53 PM
