Exhaust smells like sulfur or rotten eggs
Old 05-15-07, 11:05 AM
phollero
phollero's Avatar
Default Exhaust smells like sulfur or rotten eggs
Now I know you're not supposed to be inhaling a car's exhaust fumes in the first place but my exhaust smells really bad - like sulphur when you first light a match or a nauseating rotten egg smell.
Does anyone have a suggestion on what to try fixing? I've searched all over and the suggested fixes range from engine running too rich, bad catalytic converter, bad Oxygen sensor, bad gasoline, bad throttle position sensor.
Any experiences to share is appreciated.
Old 05-15-07, 11:56 AM
Kaiser
Kaiser's Avatar
Cat Converter.
Old 05-15-07, 02:45 PM
Xeeeeeem
Xeeeeeem's Avatar
Mine only does when i gun it for atleast 2 gears...smells like someone farted haha
Does that mean the cat is on the verge of caput?
Old 05-15-07, 03:20 PM
phollero
phollero's Avatar
Okay thanks all. I've been researching more and a bad catalytic converter is the most likely problem.
The most likely reason for the catalytic converter going bad in the first place is because of a bad Oxygen sensor. A faulty O2 sensor can cause the engine to run too rich (running with excessive fuel) which causes catalytic to fail since it runs hotter with a rich fuel mixture.
Before I jump to buying a new catalytic, I will try testing the resistance of each of the 3 Oxygen sensors and hopefully find a bad one or more. I'll replace the bad ones and see if the smell improves.
If it doesn't fix my problem, I'll start looking to buy a new catalytic converter. The expense of O2 sensors will not go to waste since it's recommended to replace them when changing the cat anyway. Anyone know what I should expect to pay for a catalytic converter?
Old 05-15-07, 03:21 PM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
change ur cat bro!
Old 05-15-07, 03:35 PM
Kaiser
Kaiser's Avatar
Dealer MSRP on the federal cat is $1500. You can find them for just over a grand brand new. The ***** of it is that you live in California and have to go with OEM style equiptment. I paid $60 for my 3" cat.
Old 05-15-07, 07:50 PM
Abear
Abear's Avatar
Haha, yeah, California FTL.
$1000+ for a Cat is FTMFL!
Old 05-17-07, 08:50 AM
Xeeeeeem
Xeeeeeem's Avatar
Would this have anything to do with my check engine light goin on every now and then and going off
Old 05-17-07, 09:59 PM
phollero
phollero's Avatar
The best way to know the reason for your check engine light is to read the code. In my case, I'm getting a code 71 - EGR system malfunction. I don't think it is related to my smelly exhaust, but I plan to get it fixed anyway. Who wants their CEL on right?
Tutorial on getting codes:
http://www.troublecodes.net/Lexus/
popek31
09-26-23 03:03 PM
bacardi11
12-06-14 10:48 AM
synrgy350
06-06-14 04:21 PM
persian451
05-07-03 11:20 AM
Quick Reply: Exhaust smells like sulfur or rotten eggs
