This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - First Generation
Thread Tools Display Modes
Old 10-12-07, 07:32 AM   #1
Aristo-cat
Trader Score: (0)
so basicly what your saying is that I need to find a 2jzgte only from an Aristo, with tranny and ECU. A USDM Supra 2jz won't work... correct?
Aristo-cat is offline   Reply With Quote
Old 10-12-07, 07:53 AM   #2
Kaiser
Trader Score: (0)
Kaiser's Avatar
Send a message via MSN to Kaiser
The wiring harness won't be plug and play like the Aristo.
__________________
2001 GS430
No modifications necessary...yet
Many of the truths we cling to depend greatly on our own point of view. -Ben Kenobi
Kaiser is offline   Reply With Quote
Old 10-12-07, 08:07 AM   #3
twojayzee
Trader Score: (0)
Quote:
Like kaiser said
Quote:
The aristo is plug and play. The usdm stuff will work but its a pita to do all the wiring conversion
__________________
twojayzee is offline   Reply With Quote
Old 10-28-07, 08:11 PM   #4
Dr Tweak
Former Sponsor - Cancelled
Trader Score: (0)
The harness won't be plug and play, just like if you got a 1JZ, or a VVTi 2JZ, or anything that didn't come from an Aristo (GS300) chassis.
If you do want to do a swap from a different car, you can, but the wiring would need to be converted. We provide this service:
http://www.phoenixtuning.com/
But with Aristo 2JZ engines being so abundant, they are the logical choice. I will probably swap a VVTi 2JZ into my '93 GS300, but that's just because I like being difficult
-Doc
Dr Tweak is offline   Reply With Quote
Old 12-10-07, 03:53 AM   #5
reese1788
Trader Score: (0)
Default Engine Swap
I have a 1994 GS 300. I want to put the 2JZ-GTE in it. I want to know everything that I need to know to make this happen. Can someone tell me how much money Im going to need and exactly what parts im going to have to buy. Thanks
reese1788 is offline   Reply With Quote
Old 12-10-07, 08:20 AM   #6
Lexatlast
Trader Score: (5)
Lexatlast's Avatar
Send a message via AIM to Lexatlast
reese...
thats exactly what this whole thread is about.
__________________
01 MSM IS3 - We Begin Anew
95 BO GS3 Na-T - Our Journey - RIP
NEF/NELOC - CL Folding - TLN #711
Lexatlast is offline   Reply With Quote
Old 07-14-09, 09:23 AM   #7
dbs gs300
Trader Score: (0)
Default speedo problems
i have a 93 gs300 with an chaser 1jz vvti and auto trans. the trans has no place for a speed sensor so how do i get my stock speedo to work also will the tack work if i do the jumper as described before. also looking to upgrade the turbo and exhaust manifold any suggestions
dbs gs300 is offline   Reply With Quote
Old 12-29-07, 05:48 PM   #8
slvr-2jz
Trader Score: (0)
kasier why do you use a supra throttle cable, did your front clip not come with an aristo throttle cable? also what year supra waterpump should you get? also the harness extension you speak of what vendor should i source that from?
slvr-2jz is offline   Reply With Quote
Old 12-29-07, 06:27 PM   #9
Kaiser
Trader Score: (0)
Kaiser's Avatar
No it did not come with a cable. Not sure why. The waterpump was from a 95. If you were able to find an extension harness it would be from a company called Fields. They were discontinued a while ago but I saw 2 for sale on the SupraForums classifieds within the last 3 months or so.
__________________
2001 GS430
Old 12-29-07, 06:54 PM   #10
Dr Tweak
Trader Score: (0)
I could make you one if you need one.
-Doc
Old 12-29-07, 07:14 PM   #11
slvr-2jz
Trader Score: (0)
im gonna try to use my throttle cable if my front clip come with one. if not what year supra throttle cable did you get, did you get it from the toyota dealership for 40$? doctor tweak you said you could make one,, how much will you charge for an extension and your talking about going to toyota and buying the plugs and making and extension? send me your phone number dr tweak and keiser... that way i can call you and ask you a whole bunch of question. ill prolly have a whole bunch more questions once my clip arrives...
Old 02-26-08, 01:49 AM   #12
status....
Trader Score: (0)
did anyone try using the fields harness that mvp motorsports sells on their swap and how long is it?
status.... is offline   Reply With Quote
Old 02-26-08, 07:34 PM   #13
Dr Tweak
Trader Score: (0)
I have those patch harnesses in stock, they are $275, free shipping.
-Doc
Old 03-28-08, 11:57 PM   #14
lxs_aristo
Trader Score: (0)
what about the diff? I am doing the swap on a 94 gs300. I was wodering if a supra's would fit if you changed the three pronged peice from the gs. I found a torsen lsd with a 3.8 final from an aristo, but would have to order from japan. I dont like the open diff that it comes with, and dont trust it with the added power.
lxs_aristo is offline   Reply With Quote
Old 03-29-08, 01:06 AM   #15
twojayzee
Trader Score: (0)
Quote:
how much did you find the diff for in japan ?
__________________
Tags
300, aristo, drive, exterior, fuel, gs, jdm, jzs147, lexus, nat, parts, pinout, pump, shaft, supra, swap, vip
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
