Single Din or Double Din Radio
Old 11-02-14, 04:45 PM
TRACKMKIII
TRACKMKIII's Avatar
Default Single Din or Double Din Radio
Just curious if you guys are running single din or double din aftermarket radios. Can you anyone post a pic of your single or double din set up and let me know if you have noticed any advantages or disadvantages of either. I wanted a double din because I thought the single din might look out of place but I have a pretty nice Kenwood with bluetooth and a ton of features just sitting around doing nothing plus double dins seem to cost a bit more. I don't really think there are any real advantages of a double din over a single din except maybe touch screen but I don't really want that. If I go with a single din I want to find an installation kit that with give it a finished look instead of just a head unit with a giant pocket below it. Thanks for any input!
Old 11-03-14, 10:45 AM
onelt1
onelt1's Avatar
Double din, but the install kit isn't wide enough. It doesn't make a clean looking install.
Old 11-06-14, 09:26 AM
MyGS3
MyGS3's Avatar
I'm a fan of the double din. I don't like the space the single din leaves after install. I think my install came out pretty clean.
Old 11-06-14, 10:19 AM
TRACKMKIII
TRACKMKIII's Avatar
That's a pretty nice setup!!
Old 11-07-14, 11:03 PM
TRACKMKIII
TRACKMKIII's Avatar
Where did you guys find your information for installing the aftermarket head units. I saw the write up in the DIY section but it was pretty confusing to me and the pics no longer work. Does any company make a jumper harness or do I still have to hard wire it in? Thanks in advance!!
Old 11-08-14, 07:48 PM
onelt1
onelt1's Avatar
No jumper will work, unless you make your own. Most just hard wire, that's the way mine is. When I first hooked it up I butt-connected all my wires, but I went back through and soldered all my wires and tucked all the extras back out of the way.
Old 11-08-14, 08:32 PM
TRACKMKIII
TRACKMKIII's Avatar
So you just ran all new wires from the headunit to the speakers? I want to wire the new head unit using thr existing factory wiring to avoid running new wires all over the car. Is that possibly?
Old 11-09-14, 02:31 PM
onelt1
onelt1's Avatar
Not sure. I have seen somewhere at some point someone being able to get the factory wiring to work with the aftermarket stereo. I have two amps so I just ran speaker wire to my 4 channel amp. I did try to hook up my factory speakers to my current head unit and that didn't work so I bought an amp and ran new wire. Running the wires isn't the hard part the hard part is trying to make everything look like a professional did it. I will try to look for that wiring/head unit thread tomorrow when I don't have to work.
Old 11-09-14, 07:17 PM
onelt1
onelt1's Avatar
Ok so you seen mine from up close here is a pic from further back like MYGS3.
Old 11-10-14, 05:42 AM
TRACKMKIII
TRACKMKIII's Avatar
Looks good!!
Old 11-10-14, 04:31 PM
onelt1
onelt1's Avatar
yeah not to bad but I think it still needs to be more flush. Maybe its just me.
Old 11-10-14, 05:58 PM
TRACKMKIII
TRACKMKIII's Avatar
What part exactly? It looks pretty flush to me.
Old 11-10-14, 06:43 PM
onelt1
onelt1's Avatar
The install kit. I guess you can't really see it but the left side is further away then the right. It bothers me every time I get in my car.
Old 11-16-14, 08:06 PM
TRACKMKIII
TRACKMKIII's Avatar
Anyone using a single din?
Old 12-15-14, 04:58 PM
CARSNBIKES
CARSNBIKES's Avatar
I'm using a fairly inexpensive jvc double din head unit, my amp blew up so its what powers my whole system.
Quick Reply: Single Din or Double Din Radio
