Brake light on dash problem
Old 11-16-06, 06:55 AM
bmoon_007
bmoon_007's Avatar
Default Brake light on dash problem
What's up guys, i've done some searches and can't find the problem. When taking off from a stop, my brake light indicator comes on then goes away after 10 to 15 seconds. This happens everytime I come to a complete stop. Please let me know what's the problem.
Thanks,
- b
Old 11-16-06, 07:19 AM
BrooklnLex
BrooklnLex's Avatar
Question
Thanks,
- b
This keeps happening to me as well. When ever I check the brake lights they all seem to be working, but the dash indicator disagrees. Could this be an early indication that the lights have a short life ahead of them?
My GS, "Baby", has been doing this for about a month now!
Old 11-16-06, 05:10 PM
justfixit
justfixit's Avatar
Rear light indicator is amber colored
Brake light is red colored
If your amber rear light indicator is coming on, you have a bulb that is not working. If it is a tail light bulb (parking lamps) the indicator will come on when you turn lights on and will go off when you turn lights off. If it is a brake bulb not working it will turn amber light on when you press brake pedal and remain on until you turn key off.
If your red brake light is coming on when you come to a sudden stop or during a mild to hard acceleration then most likely your brake fluid is low. As you stop or accelerate it changes the actual level of the fluid in the resovoir. Make sure your brake fluid is at the full mark.
Good luck
Old 11-16-06, 07:13 PM
Tammy
Tammy's Avatar
If the brake fluid is low, you may wish to inspect for wear of the brake pads.
diverchris
07-18-13 05:39 AM
Columbus
IS - 1st Gen (2001-2005)
07-06-12 04:32 AM
bloo1987
RX - 1st Gen (1999-2003)
06-26-07 01:09 PM
92 SC400
Lighting
10-17-06 06:08 AM
Quick Reply: Brake light on dash problem
