JDM aristo XENON retro PART 1
I will be doing a xenon S2000 retrofit on a set on jdm headlight for a GS300.part 1 ,we will be removing the orange turn signal reflectors.
pay close attention students.
first we need to remove the lens from the housing.
you can do two things.
1.Use a heat gun.
2.Put the headlight in the oven.This requires you to pre-heat the over at 200 degress.once it's hot ,you will turn off the oven,put the headlights for about 2 minutes.{use leather glove,cuz it's hot.}seperate the len and housing.done.
1.Use a heat gun.
Now you can remove the orange reflector.There is one small philips screw holding the inter trim.Unscrew it.The orange reflector is glued to the trim.You can pop it off with a flat head screw driver.
Need to make brackets to mount on the OEM location.This way you can aim the projector with aimming screws.NO GLUE WILL BE USED ON THIS XENON RETROFIT.
lex4jess2, the oem sc430 foglights came in halogen projectors, and you are just modding it with an oem hid retro fit right? wow that is so impressive, i would love to sport that on my sc!
great job you're doing, very inspirational for a lighting wh0re like me.
